Stock plans for steel 50ft Ketch
Discussion in 'Boat Design' started by paul, Sep 2, 2001.
  1. paul
    paul New Member
    Hi all.
    I am looking for stock plans for a go-anywhere, steel, radiused chined cruising yacht. Reasonably traditional looking above the water line, preferably a gaff ketch with a marconi mizzen (to keep the rig cost down) Fin and skeg under the water for a reasonable turn of speed. I am very much into single handing, and as I am planning to go (back) to the high latitudes I would like some form of interior watch keeping place - a traditional pilot house??
    I am looking at Dudley Dix and Ted Brewer, I think I have visited most web sites but I would be grateful for any suggestions or recommendations or designs that are not on-line.
    Thanks!
    Paul
  2. Guest
    Guest Guest
    50' steel ketch
    Certainly not traditional, but aimed at short handed sailing. Have a look at the rig (single-masted ketch/cutter) on the monohull section of my site www.RunningTideYachts.com.
    I have missplaced my original hull drawings but it is described as a twin asymetric keel vessel. The deckhouse contained a small saloon table and was located over the engine installation. This area was intended as a comfortable inside watch location during inclimate weather and could be provided with a hand held steering control. From this central raised mini-saloon you stepped down into the passageway to the aft cabin on the port side, and on the other side you stepped down into the captain's berth.
    Regards, Brian Eiland
  3. Stephen Ditmore
    Likes: 44, Points: 58, Legacy Rep: 699
    Stephen Ditmore Senior Member
  4. Roy Abrams
    Roy Abrams Roy Abrams
    I have designed a 50 completly for myself single handed all done down to wiring diagram including steel mast Email me
    royabrams@btconnect.com
  5. Polarity
    Likes: 7, Points: 0, Legacy Rep: 148
    Polarity Senior Member
    Thanks Roy
    But I bought a design from Ted Brewer and worked with him on some modifications as well as converting all his paper drawings to cad. The result is in my gallery here
    http://www.boatdesign.net/gallery/showphoto.php/photo/21/password//sort/1/cat/500/page/2
    Now I have postponed the trip it was designed for and bought an Aluminium singlehanded race boat instead..
    http://www.boatdesign.net/gallery/showphoto.php/photo/1241/password//sort/1/cat/500/page/1
    Good luck with your build. Whats your plans for her when she's built?
    Paul
  6. Roy Abrams
    go sailin
