Stiletto 23 with Aftmast Rig
brian eiland
Senior Member
Joined
Jun 3, 2002
Posts
5,658
Reaction score
333
Location
St Augustine Fl, Thailand
EXPERIMENT
This might make for a very interesting experiment,..and much cheaper than building a new vessel.
Take one of these very hi-perf Stiletto 23 and place a version of my aftmast on it.
Stiletto 23 Sailboat Review, Specs, and Listings
Technical specs and review for the Stiletto 23 (1985). A super light design built for high-performance sailing spanning 23' length, sporting a Fractional Sloop rig.
www.listingsport.com
This is a sketch of the new framing structure I had suggested as a possibility in such an experiment,..
This image has been resized. Click this bar to view the full image. The original image is sized %1%2.
1792837035606-webp.210795
I'm thinking the original hulls are usable, and the mast tube cut down in height,...maybe even the original crossbeams with addition reinforcements???
That mast base placement beam/structure plate would have to be moved forward in keeping with my latest decrease in fwd mast rake, and the aft crossbeam would need additional reinforcement to carry the 'dual backstays'
I've already found several used ones for 5-6K. It would be fun to make one of these vessels sail really well with that rig of mine, and I really think it is possible.
Perhaps we could think of this experiment as one utilizing a BIG MODEL-boat.
Might be interesting to provide diagonal X stays in the horizontal plane between the crossbeams? This was a (bridge-deck) solution long ago on one of the BIG cats in 'The RACE',.....stiffened up the vessel.
Carbon Fiber I-Beam ?
Does anyone know who/where in Florida I might have that I-beam constructed?
...or could be elsewhere on the east coast, ....its just more convenient in FL where I am living now.
I-Beam or Other Configuration?
Just wondering if there might be another beam configuration that might be built in a more simple fashion?....with the continuous wrapping motions utilized with mast or tubes?
EDITED: In really like the I-beam configuration for a number of reasons. Going to have to consult with some carbon fiber builders to see what they recommend.
(This is the singular item that requires custom construction by a specialty builder. Most all the other constructions would likely only require consultations with a good rigging company, and good sailmaker)
EDITED 2: I suspect that the I-beam frame structure does NOT have to be that deep under the mast,..but rather the lower flange portion of the beam itself needs to be sufficiently strong.
I've always appreciated the French sailors for their capabilities to look at progressive ideas of getting their multihulls sailing around the world and racing courses. They seem to be able to more readily accept 'out-of-box' thinking.
With that in mind, I'm thinking I could more easily find a French gentleman who might be interested in my 'aftmast on a Stiletto23 experiment',...(and where it might lead with future multihull CRUISING boats?).
By choosing that used Stiletto craft I've chosen a vessel that would NOT require any real specialty to picking a builder to construct a new boat. The primary item I would need to have built is that carbon fiber I-centerbeam (H-beam). For the remainder of the vessel, collaboration with good rigging service company would be good.
All this could be done for a small investment considering all things these days.
The have thus far only recently pitched the idea on 2 boating forums, nether of which are French. Would you have some ideas as to where I might reach some potential French sailors with the idea,...forums, press releases, etc, etc.,....places where more European readers might find the idea??
Just in case anyone has not seen my new aftmast rig (on a much bigger boat),..
Odd how someone who goes on and on about a bare mast causing drag comes up with a design that has the longest bare mast of any rig.
I went 'on and on' about the bare mast because I had so many naysayers addressing it as a problem. And I admitted it was a problem, particularly as my original rig plan had the ENTIRE mast as a bare mast.
I've cleaned that up somewhat with the new rig configuration,... that only leaves that upper portion as a bare mast,...and some of that may yet be modified.
