rangebowdrie
Senior Member
- Joined
- Nov 28, 2009
- Posts
- 342
- Reaction score
- 148
- Location
- Oregon
To expand a bit on the above post: Even using a diesel engine at ~1800 RPM, as in typical generator service would require a reduction gearing in the 25>30:1 ratio.
That's some serious reduction, it's going to take a lot more that some truck transmission to do that.
To do that with single-stage reduction would require some massive gear boxes.
If you can use a transmission that will give, say ~4:1 reduction in 1st gear, thence to a truck rear-end with ~4:1, thence to a final chain drive at ~2:1 you'll be getting in the ballpark.
Hydraulics work good, but they do make a LOT of noise, and the controls, valves, coolers, pumps for the coolers, accumulator tank(s), and huge amounts of high-pressure supply lines can push costs into low earth orbit.
Blow a fitting/hose? You don't even want to contemplate that scenario.
