Stephen Ditmore
Senior Member
- Joined
- Jun 12, 2001
- Posts
- 1,634
- Reaction score
- 77
- Location
- South Deerfield, MA, USA
I'm going to relate what I understand to be Harry Schoell's view in response to your questions, Tom. The purpose of the curved planform of his steps is most likely to bring the step at the chine forward enough that it's immersion is unlikely. It is particularly unlikely if the hull is both high deadrise and on the wide side, so it carries its chine high. Beyond this, he felt (as of 6 years ago) that additional ventilation was unnecessary, based on measuring air flow through small tubes in his models as he towed them to measure bottom pressure.
Harry felt the trim angle should decrease a little at high speeds, and for this reason he uses a centerline flat aft of the chine, but not forward of it. The data I've seen suggests that 4 deg is near optimum at most speeds, however.
Harry also believes that most control problems occur because curvature is immersed forward, and addresses it with his "delta-conic" bottom surface, which puts the straight ruling lines of the developable bottom shape approximately along the flow/spray path.
Harry's typically used spray strakes, but believes that they are far less important than getting the bottom shape right, and I think a number of other experienced designers would agree with him there. Mostly what they do is reduce the bottom area whetted by spray.
My reason for favoring a narrow flat along the centerline is that I think it improves lift and prop flow with a minimal impact on ride (as long as it is not too wide). "Pads" near the stern have become quite common. I favor carrying the flat farther forward.
The issue with cats is getting them to lean into turns. Any thoughts on that?
