Steel sailing boat, some thoughts...
Discussion in 'Sailboats' started by eiltrenova, May 3, 2011.
  1. hein mk
    hein mk New Member
    moin(somthing like good morning ore have anice day)
    Yuor pictures shows the shortkeel-version of the sea dog with 1.50m draft(about 5feet) the boxkeel should bee balasted with 1500kg lead
    the thicknes of the shellplating is 3mm.
    I did build the longkeel-version with 1,35m draft,and instead of the steel-deck.doghous,cockpit one with an marineplywood-deck,doghouse,cockpit.
    some photos of building
    greetings hein
  2. eiltrenova
    Likes: 2, Points: 0, Legacy Rep: 46
    eiltrenova Junior Member
    Thanks Hein,
    Would you know have available any of the listed plans that correspond to the ones of this particular build?
    1 lines
    2 table of offsets
    3 construction plan
    4 construction plan sections
    5 deck, superstructure
    6 sail plan
    7 boxkeel - draft 1,55m, lead 1220 kg
    8 spade rudder
    9 interior layout
    10 interior sections
    11 interior sections
    12 deck plan
    13 aluminium spars
    14 rigging list
    16 sail insignia and sail number
    17 boxkeel, draft 1,35m (iron punchings with cement), 1500 kg and rudder with skeg
    19 construction plan longitudinal frames
    20 lifting keel, draft 0,61/1,90m, lead 800 kg + inside ballast 750 kg
    21 lifting rudder, transom hung
    22 bilge keels, draft 1 m (cast iron), 2 x 750 kg
    Once again many thanks...
    best wishes
    Andre
  3. hein mk
    hein mk New Member
    moin
    When you like to refit this boat,yuo dont need this plans.What yuo need are:much experiens about metalwork:cutting,grinding,welding,painting and about woodwork and design for the interior,tools and 20.000euro for materials,engine,sails,ropes and so on.Dont forget the investment of about minimum 600h of hard work.some more pictures of my version of a v.d.stadt29 sea dog,
    hein
  4. eiltrenova
    Hein,
    Many thanks for your reply. Yes, I realise your figure might be realistic, though perhaps if everything had to be done to make it a boat to 'sell'...but the question I raise is the following: do you think I could get it in the water with just the following basics (engine-sails, electrics and welding/painting the shell) with less money....all the rest like wood on the deck, inside furniture would come years down the line, or perhaps I leave it set up like Bernard Motessiers sailing boat....what are your thoughts of the costs. I think I would need a welder to the the welding, unless I don't do a course and learn myself...
    Many thanks
    Andre
  5. eiltrenova
    thanks for the photos, and congratulations on how you have set it up...
    thanks again
  6. hein mk
    hein mk New Member
    moin
    It is possible to get the boat in to the water with some basic things like new paintings(outside and inside)sails,ropes and perhaps a outbordmotor,when you are sailing in warm regions like spain aperfect interior is not needet.
    But sails and the motor are the expencif things of a boat
    hein
  7. eiltrenova
    Many thanks for your advice...
    best wishes
    Andre
