STEEL HULLS with Composite Superstructure / Topsides
Not a bad article.
A couple of comments: Steel medium to heavy displacement boats can be lighter in hull construction than all other sensible forms of construction (except alloy) once the length gets over around 50 feet.
Steel boats are stiffer globally than other construction methods.
The reason for the massive reserve strength of metal boats in a grounding or collision is the difference between brittle fracture ( wood, Composites, ferro cement) and a metals yield point. Metal still has a long way to go after yield before it reaches fracture, that means that a metal boat has a damage tolerance to failure significantly higher than a material with brittle failure.
I've been involved in salvaging boats that have run up on reefs and rocky beaches and been worked by the waves. Often the metal boats and particularly smaller steel craft are often pulled off with only very minor damage, sometimes no damage at all except to the coatings. Composites and wooden hulls are usually constructive write offs and are broken up on site with an excavator after stripping and they don't take well to being dragged back over rocks to get back into the water.
Metal boats are the most popular in the Pacific for remote cruising, I ran onto a coral head at 7 knots once in a 45 foot steel boat and put a hand sized dent in the boat. The impact was terrifying, the damage required a little filler ! It's not just financial insurance.
But I keep reiterating that steels boats must be designed by someone who understands the maintenance issues. No inaccessible areas inside around bilges ports, stern tubes rudder ports, hull fittings and deck hatches. All linings in these areas should be easily removable. The factory build European production boats were a disaster in steel. They were built to last 20 years and you can find them rusting away in many areas of the world. They really gave steel a bad name and fortunately for the consumer they have moved to alloy now.
Oh and steel doesn't rust due to oxygen, oxygen is a requirement but not the cause of rust, bare steel in pure oxygen is completely inert.
formula Fe2O3. It is one of the three main oxides of iron, the other two being iron(I) oxide (FeO), which is rare, and iron(II) oxide (Fe3O4), which also occurs naturally as the mineral magnetite. As the mineral known as hematite, Fe2O3 is the main source of the iron for the steel industry. Fe2O3 is ferromagnetic, dark red, and readily attacked by acids. Iron(III) oxide is often called rust
http://en.wikipedia.org/wiki/Iron(III)_oxide
But inert in pure oxygen?
Not that I doubt you, but hard to get my mind around. :)
Can you cite this information?
Many years ago we put a big steel power cat onto a coral head in the Wessel Islands on a falling tide. It was the wet season, no visibility and poor charts.
Anyway, the tide went out, boat heeled, hung up on one hull. Lots of nasty noises and a bloody big list. Couldn't run generators etc so the beer was getting warm. Tide came in, we floated off, no damage other than scraped paint and a need for the skipper & deckie to put on a load of washing after the underwear change. Cold beer resumed. All good.
I like steel boats. They make Braille navigation more survivable.
PDW
Have a look inside a steel O2 tank and you should find it clean so long as the gas was 'dry'.
It's pretty basic material science which is why I mentioned it, to form rust from Iron you need some ion exchange AND available oxygen the lattice doesn't give it's electrons up that easily. Oxygenated water will do.
If steel simply oxidised in the presence of O2 the material wouldn't exist outside of a lab curiosity since the oxide is porous.
Of interest; In a range of alkaline conditions steel is passivated, that's why steam ships engineers had to descale boiler tubes when the ship was in port and the rest of the crew was seeking the delights of the city. A property of steel they must have cursed ! It's also why lime-cement wash protects bare steel very well and why reinforcing doesn't corrode in concrete while it's alkaline.
Aluminium is at a much higher energy state and reacts instantly with oxygen to form what is bascially a ceramic coating. Aluminium will burn in a pure oxygen environment once ignited, just as magnesium burns in atmospheric O2 levels. Aluminium can be ignited in a pure O2 environment simply by scratching it with a piece of steel.
I understand and have seen the phenomenon you describe.
also why ancient auto bodies last longer in our desert states, a boon to restorers.
Iron WILL burn, though. Even in air. Light off some steel wool! :D
And iron and aluminum burn excellently together. Thermite. :)
Entering closed tanks is entering a death chamber if its been closed for a long time, all the oxygen combined into rust, even in dry climates.
PDW
Collisions are common for cruising boats. I've never yet met a long term cruisier that didn't have a potentially dangerous encounter at some stage, dragging anchor is a very common cause.
Boats over a few tons built of steel ground better than alloy. Alloy spalls and the 'cutting tool' can get a bite and does a lot more damage in bending as well. If you intend to explore the uncharted shallows ( many suitable anchorages ) you either need good local knowledge, or a boat that doesn't mind the odd clonk. That's where catamarans often come unstuck, we see total constructive losses from groundings that a well build monohull gets no more than cosmetic damage from. Not just ULDB's either.
But there are disasterous monohull materials for collision too and for example my old ferro ketch is on the bottom near Cygnet (a subsequent owner) after encountering a rock.
I dragged down onto a submerged wreck once, that was a bit concerning. Another time a series of combined waves once gave us unexpectedly high waves with their associated unexpectedly low troughs and 2 m of water below the normal troughs disappeared, the boat was dropped quite hard on a rock shelf 3 times before normality resumed and we got out of there.
Yes good point everything needs qualifying and all metals burn under the right conditions.
Steel wool burns well, but it's a bit different as the high temp to sustain the oxidation reaction is maintained because there is no effective heat sink. But even as a foil it's a different scenario. It's a bit like the difference in igniting fine crushed rock suspended in air or trying to burn rocks. But you can ignite a large block of Aluminium very easily with no more than scratching it with steel ( in high concentraitions of O2)!
Thermite is a mix of Iron oxide, (not Iron) and Aluminium but it needs to be finely ground. We used a themite lance once ( or rather the welder did) to shrink a large shaft of the crown wheel of a bucket dredge so it could be disassembled. It just bored straight through, great tool. You can cast steel with a thermite furnace and weld assemblies like railway tracks.
Yeah - that's why, when the opportunity presented itself, I increased the thickness of the keel shoe from 200 x 25 to 200 x 40. Saved me quite a bit of money as well both in not buying new steel as opposed to the used stuff, and the extra mass meant I need less lead. I did ask the designer's consent first.
So, provided the keel hits and not a corner of a rock etc into the hull plate, I'm not too worried about doing more than scraping the paint off. Bernie Harberts hit a submerged wreck all standing in a Witch off of East London IIRC. He skidded right over the top of it, no damage except to the keel paint. His keel shoe was a lot thinner than mine.
PDW
Building a Steel 41-plus DUCK in Turkey
Interesting building discussion and photo presentaton
http://dieselducks.com/41-plus%20construction%20Page%201.html
Note mention of 'floating-longs system' on page 2 & 5
And how about his simple reasoning for steel boat construction,
I make NO claims to being a metal worker however, that don't stop me from opinions, and, it seems to me with the "floating longs" and long plate way of building described in Random Thoughts at georgebuehler.co, little if any fill stuff is needed. The hull comes out "fair" and when painted with a flat or semi-gloss paint, looks great. The benefit is if you bang a dock hard you don't chip a 1/4" or bondo, and painting a "ding" is less hassle than a wood hull because there won't be anything beyond the paint surface. Compare that to fixing a "ding" in some Awlgriped or the like finish....
The plate on my hull is fair and the longs weren't allowed to 'float' out to the steel hull plate as it was applied. In fact the plate was pushed against the longs and frames as it was tack welded.
The difference as I see it is, the designer of my hull knew steel and drew a boat that could be plated as designed, plus I took a lot of time to actually build to the design by lofting out on a 1:1 scale and making all the frames etc before I tore up the full scale set of lines.
I've seen it done both ways and I prefer to do it properly, which is not allowing the longs to float off the frames when the designer specifies that they don't.
I definitely would not trust *anything* George Buehler said about steel boat building; at best he's repeating second hand information as he doesn't weld and has never built a steel boat himself.
Besides there's a dangerous implicit assumption in allowing the longs to float, that being that the steel sheets you're working with don't have any curvature themselves as delivered or as cut, before being fitted to the hull. This is a very risky assumption to make IME. I pushed quite a bit out of my plate, some inherent and some generated by heat distortion when the plate was cut. And yes, I did use a plasma cutter.
Whatever - I'm happily if slowly fitting out and that's a right annoying process regardless of hull construction etc. Damn sight easier to fit transverse bulkheads to frames if you don't need to worry about gaps around the longs though.
PDW
Steel Protective cleaners & coatings (Hull, etc)
....from a recent Designfax newsletter
Henkel Corporation has introduced a new, water-based reactive autodeposition coating, Bonderite M-PP 930C, formulated specifically to deliver a uniform, defect-free surface coating on raw cast components and ferrous metals. This paintable epoxy-acrylic urethane coating easily coats both the inside and outside of complex components and delivers enhanced corrosion and abrasion resistance, excellent thermal stability, and superior edge protection, abrasion resistance, and flexibility. The coating covers the entire inner diameter of cylindrical parts, controlling warranty exposure.
http://henkeladhesivesna.com/henkelna/10400_LT6267_SurfTreat_eBrochure_Final251798.pdf
...excerpt
HENKEL BRANDS
ALODINE: Registered as a trademark in 1946 as the conversion coating for aluminum substrates, Alodine® is a series of conversion coatings
that improve paint adhesion and provide corrosion protection for light metal substrates. These coatings include metal pretreatments
and post rinses for light metal pretreatments.
BONDERITE: Since the early 1930s, Bonderite® has been well established in the automotive and metalworking industries as a brand for
conversion coating processes and chemistries to improve paint adhesion, corrosion protection and wear resistance to ferrous-based
alloys, mixed metal alloys and plastic surfaces. The products that make up the Bonderite® brand include process line chemistries,
cleaners, pretreatment chemistries including activators and conditioners, conversion coating chemistries, post treatment chemistries
(including rinses and passivation), as well as auxiliary products including toner, additives, accelerators and neutralizer.
P3: Registered in 1894, the P3® brand didn’t begin to represent cleaners until the late 1920s. These cleaners are for metallic and
nonmetallic surfaces, fouling prevention and corrosion protection, together with disinfection of water and use with wastewater treatments.
These products are liquid/powdery products designed for use in low- and high-temperature applications at different pH ranges (acid,
neutral and alkaline), and in high-pressure applications, depending on customer conditions.
CNC-cut Metal kits
There is an interesting affirmation article concerning CNC-cut metal kits in the latest issue (Apr/May) of Professional Boatbuilder:
http://www.proboat.com/table-of-contents-148
Precisely engineered CNC-cut metal kits simplify custom and production projects at aluminum sailing-yacht builder K&M and steel-motoryacht builder Jetten, ..both in the Netherlands
In case you are unable to access this article on-line, I will just hi-lite a few of the notable observations.
Today, at K&M Yachtbuilders, metal components delivered to the construction hall are far more refined: Precut stringers are the precise shape required to yield the finished hull, and they arrive from the computer numerically controlled (CNC) laser cutting facility with an intricate pattern of notches cut halfway through their depth to interlock with the transverse frames, which in turn have a corresponding pattern of narrow cuts around their outer curves. These pre-cut structure members with cutouts, coupled with precut hull plating, assure a stronger hull than conventional build, and require fewer highly skilled builders, and much shorter production time on the shop floor.
Building with kits (alum and steel) saves much of the expert but time-consuming manual work, because parts come precut from CNC-laser, or CNC-plasma cutting machines and fit together only one way....
I like this new way of building boats. Nevertheless I must admit with the old method the welders on the shop floor had a very big part in making the hull what it should be. With the cleverly engineered metal parts that fit together to become a firm structure without the workers manipulating any part, construction follows the procedure planned by the engineers. Still it is a fascinating process to see a yacht take shape following the arrival of a pile of metal parts. And we can build much faster now.
When we build with metal kits, the hull comes out smooth, with a lot less finishing work.
A 50' boat can be finished within months. It allows welders and yard professionals with less experience to build a strong, lightweight hull exactly to specification in a predicatively short period of time.
We had a lot of demand for the kind of quality built steel motoryachts we build here. ...That is why the innovation program was started ( the government funded project mentioned earlier, Virpack's Smart Kit was one outcome).
At Jetten Yachting one of the first boats built by the Smart Kit method was a 40' steel-hulled cruising yacht. The yard had built hulls to this design previously, but always by traditional methods. The same boat built from a Smart Kit was finished in just eight months, cutting build time in half.
Building with kit-ed CNC-cut components is so efficient that just 2 weeks after construction began, the hull of this Bestevaer at K&M is ready for plating, which has started at the garboard.
Another savings of the Smart Kit for Jetten is that not all plates must be cut by laser. Laser metal cutting allows no more than 0.1mm deviation from computer drawings, but less expensive plasma cutting is now as precise as 0.5mm-0.8mm maximum deviation.
So we have the main construction of transverse frames and stringers laser cut, but the hull plating plasma cut.
The process of optimizing cost and build time for our yachts continues. The Smart Kit gets smarter all the time, while we also try to improve on yard logistics and cost efficiency. The lower the cost of our yachts, (and the shorter the build time, BE's edit), the bigger our market
Summary of My Postings on this Subject Thread
Composite Superstruction Considerations
There are any number of notable ship constructions where a lighter-weight superstructure has been sought out for a basic metal hull. Alum topsides over a steel hull comes to mind for a number of larger yachts and navy vessels. Creative bonding techniques have had to be invented for these cases. Likewise the joining of composite superstructures onto steel hulls requires creative thinking about both the mechanical and the 'chemical' bonding of these two very different materials.
I use the word 'chemical' in the sense of adhesion. There are any number of mechanical methods of bonding that are conventional in manner. It's the adhesive bonding that is continuously under development with ever-stronger, greater adhesion products. I think we are currently at a point that we have a number of very good adhesive products that can join our composite superstructures to our steel hulls with extreme confidence.
My thoughts are this 'transition' from steel to composite should take place at the hull-to-deck interface, NOT at the deck to cabin superstructure joint. In other words I favor a composite deck, ...more specifically a sandwich-cored composite deck onto which the rest of the cabin/superstructure is attached.
I've witnessed years and years of sandwich cored composite constructions. Basically it boils down to using 3 types of cores; 1) balsa, 2) various foams, and 3) honeycombs of either alum, Nomex, or polypropylene. Generally the balsa cores have won out over the foams for deck fabrications due to their greater stability under the extremes of tropical heating. But balsa cores have a significant history of susceptibility to rot from water penetration at various hardware attachments and migration of water along the core-to-skin bond line.
Alum & Nomex honeycombs are a little pricey, and extra care must be exercised to obtain a good bond with the very 'thin edges' of the honeycomb chambers. Polypropylene honeycomb however has a fiberglass cloth scrim thermo-fused to its cell structure,...a very consistent bonding that doesn't provide voids for water to migrate across. This 'scrim layer' in turn provides a 100% bonding surface for the fiberglass skins to be applied to. And the polypropylene material itself is totally rot proof in the case of any water penetration.
I've come to the conclusion that this 'poly-core' material is the best choice for my composite decks and superstructures. Poly-core is one name the Aussi's and NZ boat builders term it. They actually pre-fab sheet panels (akin to sheets of plywood) of these materials in a controlled environment, and subsequently computer cut those sheets into specific panels that will be joined together to form a structure, a bulkhead, a deck section, a cabin side, etc., Here is one example
http://www.polycore-australia.com.au/
NidaCore and Plascore are two polypropylene honeycombs better know in the American market. But neither of two produces have been reformulated into pre-fab sheets/panels for some reason?....perhaps not as great a demand for kit-boats here in the USA? It could be easily done though if there were sufficient demand
For reference here are a couple of other pre-fab panels utilized by these kit boat designers, Duflex, Durakore. But these panels utilize balsa or foam at their cores.
http://www.duflex.com.au/duflex2/
DuraKore Composite Panels | ATL Composites http://www.atlcomposites.com.au/atl_composites2/products/composite_panels/durakore
one the first page of this discussion,....to be continued...
What if?,.... Canal Trawler built in Steel & Composite PP Honeycomb
What if one of the vessel designs I was thinking of building with this 'hybrid method' was something like one of these 'canal trawlers':
1)
or....
2)
Both of these are built for 'canal duty' with steel hulls and hardy rub rails. If you look thru the website for the EuroShip vessels (the first referenced above) you will find quite a lot of construction photos for their canal vessels, and many references to their computer-cut plate kits for hull construction.
http://www.euroshipservices.nl/english/
Their cabin sides and decks are also constructed of steel,.....steel skins with support framing. In order to get 'attachment points' for the finishing walls/skins on the interior surfaces, battens (often wood) need to be installed. Provisions for insulation of the living spaces, provisions for limiting condensation on the inner steel surfaces, etc, need to provided for in the cabin sides, the cabin roofs, the main decks, the interior floors, etc..
What I am proposing is to substitute a ready-made, thick, honeycomb panel of PP. It's already well insulated (trapped air space), limited or non-condensing prone, stiff, with flat surfaces on the interior as well as exterior, to which any number of final finishes could be applied. And these 'finishes' could be glued, screwed directly to the PP panels without other battens, etc. It's even possible that the surfaces of these PP panels could be simply painted, with or without a texture. Or some sort of siding could be glued on. Or some sort of wood laminate......
Some posters have expressed a concern about ship's rigidity without a steel deck. I would suggest that a sub-frame of steels beams could be placed across the ship between gunnels, the PP panel(s) placed over these support frames in lieu of a sheet of steel. Concerns about supporting items / equipments that might be added to these PP decks vs steel decks are probably no more of a concern than the extra support that would be required of the steel deck itself. If the loads are a concern for the PP deck, they would likely be a concern for the sheet steel deck. We are not talking 'work boats/construction barges' here where items are often welded onto the decks, but rather yachts,...... many with teak or synthetic teak decks.(BTW, teak onto steel decks would NOT be highly recommended either).
I actually think this type of construction could be a significant time saver.
...hmmm, I wonder if we could eliminate some of the numerous smaller ribs and stringers of the conventional welded-up steel hull and substitute some PP core material bonded to the steel skin??....might save a lot of welding time, and hull plate distortion. IDEA??
Composite I-beams for Framing Structure,....posting #78
#116 Nidacore decks
Here are some fellows (and a couple of manufacturers that appear to be quit happy with their Nidacore decks,....some conversations and photos
http://www.thehulltruth.com/boating-forum/472830-nidacore-deck-replacement.html
#117 Nidacore Decks And Stringers
Another subject thread on Nidacore decks and stringers.
Help with my restoration. Nida stringers/deck http://www.boatdesign.net/forums/fiberglass-composite-boat-building/help-my-restoration-nida-stringers-deck-35167.html
Haven't had time to review it, but it appears to have a fair amount of participates
Just might end up adopting some conventional methods, but with all of the great adhesives and non-metal, non-wood products out there these days, we need to consider new methods to employ the if it looks feasible.
I was hoping that more contributors would get a spark of an idea and post it. Sure there will aways be naysayers, but this is like a 'brain storming' sesson for new possibilities. Go ahead and list them, then we will take a closer look down the road as to whether they make sense or not. Don't start off from the negative point of view that something won't work without bring it up for conversation.
Optimistic, Brian
posting #165
Okay lets drop back and just look at one type of framing component we might consider fabricating of an alternative material,...lets take the stringer component you brought up, ...the longitudinal stringer.
How many did you have in your boat?
I'm guessing I may utilize 6-10 in my 40-50 foot vessel design. Ordinarily in a metal pleasure boat of this size these these stringers would likely be flat strips of steel welded edgewise to the hull's inner skin surface. (On commercial or military vessels I'm betting they would call for these stringers to be fashioned from L or T-shaped bar for greater strength)
We then proceed to tack weld them into place along their whole length. Next we need to fully weld them along their whole length, and we need to to this in an alternating manner so as to not warp the hull plating. I image if these 'webs' are very thick in section they would require welding on both sides to get a proper fillet with the hull skin without overhanging voids that could not be properly cleaned, then primed, then epoxy coated for a lifetime of rust free performance. Or as Mike Johns has pointed out we might run a bead of special chalk down both sides of each stringer to insure a good waterproof joint.
....NOW....
Contrast these processes with what I might suggest. I'm thinking I can pick out a suitable I-Beam of protruded glass that could be glued down to the hull's skin in the same locations as those metal stringers. I'm guessing this I-Beam of protruded glass would not have to be much 'taller' than 1.5 times that of the steel flat beam stringer., as it now has an extra wide flange set apart from the hull skin to take additional loading. AND I also have a nice wide flange area at the bottom to adhesively bond to the hull's skin.
I'm going to take a wild guess that I can bond my I-Beam stringer into my steel hull in 90% -, maybe 80% less time than it takes me to weld in those metal stringers. And when I finish 'bonding' in the I-beams I have NO more construction time required to clean. and prime, and chalk them as I did with the welded metal ones.
Basically that is one heck of a savings in time when you take into account 6-10 stringers !!
So now you ask are the protruded glass beams strong enough?? I would suggest you look thru the world of protruded and extruded glass beams. I could also double the height of these I-beams if prudent, I could make their flanges beefer, and I could extrude them of glass-filled nylon. Have you ever had any experiences with glass-filled nylon? We used it in numerous cases to make small spherical balls that supported big tall rotating mast,...and a few other spots...extremely durable stuff considering the shock loads these mast balls endured !!
Now I guess you're next question involves 'adhesives' Who would ever consider using adhesives to put a boat together?? Well lets see I think a whole lot of cold-molded vessels have utilized adhesives to bond their internals in, a whole lot of high speed powerboats use adhesives to bond their 'grids in, numerous wooden vessels, and a lot of hi-tech ocean racing boats, and those hi-tech America's Cup catamarans that I am sure use no welding to hold themselves together. Welding is not the only solution, and it is not the fastest method.
It's a brand new world, and there are new paths to consider.
by Groper
ATL have purpose design toughened epoxy adhesives for metals... they have tested steel and aluminium, the peel strength is excellent and the lap shear for bonding to both metals was approximately 28Mpa
See here -> http://www.atlcomposites.com.au/files2/epoxy_products.adhesives/techniglue-hp_r5-eng_data.pdf
and -> http://www.atlcomposites.com.au/files2/epoxy_products.adhesives/techniglue-hp_r5.pdf
posting #175
Sheer Clamp questions
I assume this is term we can apply to refer to the L-channel piece of steel that could be welded down the length of the inner skin of hull along the sheer to support the edge of the deck at this deck-to-hull joint. One side face of this channel would be welded to the hull skin, while the other would provide a 'shelf' for the edge of the deck. I assume BOTH edges of this flat surface of the channel would need to be welded to the hull's skin?
What happens to that air space that is left between the flat surfaces of the hull's skin and the channel face??
I imagine like the stringers above, this sheer clamp might also only be 'stitch welded' at intervals? Would this further aggregate potential corrosion problems with this 'inaccessible space' between the hull's skin and the face surface of the sheer clamp L-channel??
Thanks very much for your analysis of my critical thinking/analysis capabilities. :rolleyes::rolleyes::!:
BTW, Great Harbor Trawlers have built quite a number of their vessels with these NidaCore superstructures and ALL have turned out to be good boats as far as I can determine.
Great Harbor Trawlers still in business? http://www.trawlerforum.com/forums/s3/great-harbor-trawlers-still-business-11097.html
....more Great Harbor photos etc
For a significant number of years now they have been gluing decks to hulls without any other fasteners. Plexus product comes to mind most immediately. These are methacrylate adhesives, and there are now a good number of these super adhesives on the market. So those products are prime candidates for joining our decks to hulls.
There are other good candidates for our adhesion problems,...what are known as 'toughened epoxies', or could be referred to as 'rubber toughened epoxies'. Here is what one builder said about one particular product he utilized.
ADHESIVE TECHNOLOGIES
One thing to keep in mind, these 'tough adhesives' get a lot of their toughness from being somewhat pliant (not brittle). Likewise the PP honeycomb material and panels are pliant (ductile). These characteristics work together to make a really TOUGH product.
