Steel dinghies
Discussion in 'Metal Boat Building' started by Skippy, Sep 21, 2005.
  1. Milan
    Likes: 25, Points: 18, Legacy Rep: 279
    Milan Senior Member
    I was away for a few days, sorry for late answers.
    Plating overlaps are about 2 - 3 centimeters, (around 1 inch). Distance between rivets was about 3 cm. Ribs were L profile bars spaced at about 25 - 30 cm from each other. There where no stringers. Rivets were classical, type which need two guys for riveting. All together, not really advisable method for an amateur builder. These boats where build in a professional boat yards, at the time when there were still a lot of skilled riveters around. If someone wants to build a boat with thin galvanized plate today, I think it would be better to try some of the newer welding technologies which I heard have less heat distortion problems then stick.
    Rust - it is indeed one of the main disadvantages of the steel. In the fresh water, steel brush and ordinary household oil based paints offer enough protection for a very long life. In the salt water sand blasting followed by a few layers of epoxy tar cowered by some compatible finishing paint would do the trick.
    Milan
  2. Pavel
    Pavel Junior Member
    Dont know about steel dinghies, but in a spare time we have made an aluminium copy of Gerr's Nester originally designed for 1/4'' plywood with glass reinforcement. The boat is as heavy as plywood version (~60kg) (due to the strength of Alu we could save weight by reducing internal framings) but takes incredible groundings tested on rapids where the whole dinghy literally stopped on a stone several times with three people onboard. I am pretty convinced this would decapitate plywood/glass and most certainly result in a new painting scheme for steel. The boat, to our great surprise was not even dented, just a few scratches. You can look at 'still' unfinished version here:
    http://www.sailjoohee.com/Building/Nestler/nestler.htm
  3. Skippy
    Skippy Senior Member
    Very nice. Looks like it could use some foam...
  4. justin123456
    justin123456 New Member
    Any idea where to look for plans?
    I'm having a hard time locating any info on building these steel dinghies on the internet. Any ideas where to look? all these posts are 7 years old. Thanks.
    Justin
  5. bistray
    bistray New Member
    Hi, Milan,
    sorry for bringing back such an old topic. I'm really interested in building one of Dutch-style steel dinghies. I didn't manage to contact you via personal message, so had to post here. I would be glad if you could share any information.
    Regards,
    Kirill
  6. justin123456
    I tried as well...
    Yeah I looked for plans as well and no luck. But I did find this website (below) that sells kits in the Netherlands. I emailed them about availability of plans only and am waiting for a response.
    http://www.sqcboats.com/index.html
  7. justin123456
