Steel Chain plates to Stainless shroud toggles
Discussion in 'Sailboats' started by Boat Steel Keel, May 29, 2026.
  1. Boat Steel Keel
    Boat Steel Keel New Member
    Is there a recommended design to avoid coating failure where chain plates meet toggles? (See attached pics). Planning to take these chainplates down to bright metal for inspection and possible replacement. These chainplates seem to be padeyes ... not sure of the flatbar extends below deck and ties into ribs or stringers. There is no ready access below deck for inspection.
  2. bajansailor
    Likes: 1,884, Points: 113, Legacy Rep: 37
    bajansailor Marine Surveyor
    Welcome to the Forum BSK.
    The easiest thing to do here might be to cut these plates out, and replace them with new stainless steel plates?
    If the new S/S plates are tied in to the toerail and the capping rail above it, as well as welded to the deck, then they should be pretty strong?
    What type / size of yacht are you working on here? Can you post some photos of her as well please, and tell us a bit more about her?
  3. Boat Steel Keel
    I would be concerned about stainless to carbon steel weld - galvanic. I'll ask a metallurgist that I know and trust about that. It's a 1986 Steel hull Ted Brewer Kingsland - 46 ft Cutter rig.
  4. bajansailor
    Welding stainless steel to steel on steel boats is a very common practice - the steel yachts designed for Chay Blyth's first round the world race had steel hulls and stainless steel decks.
    And it is common practice to weld on S/S bollards and fairleads, toerails, bulwark caps, and any place where the paint can easily be chipped off and the steel starts to rust.
  5. gonzo
    Likes: 2,412, Points: 123, Legacy Rep: 2031
    The sharp edges is where the coating usually starts failing. You could grind the edges to round them.
    bajansailor likes this.
  6. william stokes
    Likes: 19, Points: 18
    william stokes Senior Member
    i made up ss bushes on my alu builds,
  7. montero
    Likes: 86, Points: 28
    montero Senior Member
    I think that even these slightly corroded plates are many times stronger than SS pins and toggles. I would sandblast and spray galvanize them, and paint them with a suitable paint system. Or just paint them and attach some anodes.
