Squeaky V belts
Discussion in 'Gas Engines' started by marshmat, Oct 22, 2011.
  1. PAR
    Is this a 40' belt? If not, skip all the above stuff and buy a new belt. Every manufacture makes a bad product every so often. Toss it in the drink and install a new one. Ask your parts man to look up the batch number and see how old this replacement it actually is too.
  2. FAST FRED
    FAST FRED Senior Member
    "why haven't v belts be relegated to the past like points ignition"
    Because they work , can be repaired easily , and replacement is a snap.
    Since , as noted, belts die in storage a serpentine belt and new tensioner may not be worth installing after a year or two stored on board.
    Points ignition will probably still work , after a lightning side strike , electronic will need replacement , and is seldom an on board spare.
    For loads of cruisers , that get out of sight of the marina , the old stuff is still preferred.
  3. PAR
    So does this mean you'll be installing a "make and break" on your next project, with canvas sails and hemp standing rig? Or are you a real powerboat guy and a couple of decks of rowers will suffice?
