splita boat
Discussion in 'Boat Design' started by rafterwompa1, Apr 29, 2010.
  1. rafterwompa1
    rafterwompa1 New Member
    i plan on building a 8x10 raft with 6 inch diameter pvc my question is if i split it in half put hinges on it and bolt locks on it to lock it in place when its in the water. reason i want to put hinges on it so it will fit in the back of a truck then i can put it together fast when i get to water has anyone tried this does anyone have any idea how stable it would be or does anyone have any better ideas?
  2. messabout
    Likes: 333, Points: 83, Legacy Rep: 1279
    messabout Senior Member
    PVC pipe at 6" diameter by 120" long will displace about 120 pounds. If you use 96/6 = 16 of them, you will have plenty of potential flottion. That said, my suggestion is to forget the PVC plan. The pipe will be heavy, The raft will sit very low in the water, the hinged idea will work but it will complicate construction.
    A much better plan is to build a mortar box style boat that will fit the back of the truck in the first place. If the wheel wells are 4 feet apart, you can build the boat, (call it a barge if you like) 47" wide. That'll give you better service than the pipe thingy. It will be much lighter, easier to build, and probably cost less. If you want to see a boat that has a pretty large following and is simple, cheap, stable, light, and proven....Check out the PD Racer. You can find it on the Duckworks web site. Plans are free. It is a sailboat but you are not obligated to use a sail. A small motor or a set of oars will make it go pretty good, but not fast. It will be faster and easier to propel than the pipe raft.
