tropostudio
Senior Member
- Joined
- Dec 17, 2014
- Messages
- 178
- Reaction score
- 58
- Location
- St. Paul, MN, USA
I am using Excel Solver in the Recalc button. That is used when you change the approximation interval. 'n' in cell C4 can vary from 8-2048 in both the Euler Spiral or Horn Curve worksheets. I'll start with the Euler Spiral worksheet because it was easier to put together and the first one I did.
Orange cells are for input. gey cells with orange type are calculations. Cells below the calcs are arrays that are resized and recalculated when you use the Re-Calc button. Total curve length, S, andMaximum Curvature, kmax can be adjusted, but if you are looking for the curve that ranges through x=1 to x=o, you can leave those alone. I usually leave C7, kmin, =0. That is at x=1, and asymptotic to a vertical line
It is possible to do an ad-hoc Solver routine that sets J10 to 1 by varying C6, but it really works better to 'bit bang' C6 until you get a value at J10 close to 1. The yellow highlighting indicates we are looking at varies from theta = o - pi/2 rad. O10 is the scaling factor that normalizes x max to x=1. R10 is the normalized total energy in the curve. You can look through the cell formulas and VBA macros to figure out the est. The Re-Calc Curve button cycles through updating the values and re-drawing the charts.
I'll get to the Horn Curve later, but it's similar. The geometry is just more work and calculation time than it takes to graph an Euler Spiral.
