PAR
Yacht Designer/Builder
- Joined
- Nov 12, 2003
- Messages
- 19,126
- Reaction score
- 508
- Location
- Eustis, FL
Flam is typically a convex section, while flare is concave, though both do splay outward from the hull's centerline.
Again, the Atkins design was specifically intended for carvel or batten seam, with sheet goods a possibility, after some cursing. Yep, you could bend 3/4" oak planks around that hull form, but see my comment in the previous sentence. Molding (ashcroft or whatever) can be done on about any set of shapes.
There's some twist, but this wouldn't be all that bad, just a little inventive adjective creation in the forward sections. This type of hull would do better with a building process, that can introduce some edge set in the planks, without much harm, such as carvel, batten seam, lapstrake, etc. Sheet goods (metal, plywood, etc.) can be done, but . . .
