Would you have any references you suggest I read up on (including up to naval engineering level) to better understand how the hulls in front change characteristics either up or down and might change the order/conclusions implied by the efficiency graph I relinked?
b_s
You firstly need to understand the interpretation of the data below. The data below is in terms of the PC or propulsive efficiency. This is not open water prop efficiency. The two are total different. An open water prop efficiency is as the name suggests. Take a prop with a shaft and test it with water flowing into it and out of it. It is tested with no hull in front of it at all…thus as the name suggest it is in “open water”. This means one is testing the prop and obtaining data based upon the maximum or best efficiency for that prop in open water – the data closely matches the theoretical maximums in ideal conditions – rather like your graph above. It is how we design boats with hulls…we need to know what is the efficiency of the prop at a given rpm and speed of advance (water into the prop) and the power being delivered.
When the prop is installed and we go on sea trails we measure the speed at max rpm. What occurs?...well the speed does not match the “theoretical” open water efficiencies. The simple reason is that a prop has a hull in front of it, this alters the flow of water into the prop. It speeds up or slows down or a combination of both and varies circumferentially. What this does is change the efficiency of the open water characteristics because in the open water, there is no hull in front and thus the water is clean flow and uniform. This is no longer the case.
So what we, as naval architects, like to measure is the propulsive efficiency, PC. This takes into account many factors such as: appendage, hull, prop efficiencies as well as the shaft and relative rotative efficiencies into one simple formula.
PC = EHP/SHP
EHP = Power to propel or drive the vessel when naked. Resistance of the vessel naked hull means no appendages, just the hull alone. The Power being R.V (R = resistance , V = speed).
SHP = Shaft Horse Power, or the power delivered at the prop.
In simple language is it a measure of the overall efficiency of the system. Power in power out. So whether a prop or waterjet the speed one gets on trails is influenced by many factors. Thus once a tank test is completed and the EHP data is obtained we can quickly estimate the speed of the boat given size engines. Since we now know EHP all we now need is the SHP. Thus SHP = EHP/PC. The PC for a prop boat is different to that of a waterjet boat. As a very quick rule of thumb, you can use a range of PC for a prop boat as 0.5-0.55 and a waterjet boat from 0.6-0.65. Thus it is quick to see a waterjet boat has a better overall efficiency in the system. In other words, despite props have a very high open water efficiencies, in the 0.6-0.7 range, when placed behind a hull, all the changes to the flow of the water into the prop, the inclined shaft as no longer horizontal as in the open water test and several other factors, the overall efficiency drops.
But as always there are caveats. The efficiency of a waterjet boat changes when the LD (Length-displacement ratio) starts to get low. The heavier the boat is for its length affects the waterjet more than a prop. Also slow speed, again starts to be much less efficient. So another rule of thumb. Below 25 knots (note I have not used Fn) props are generally preferred and below LD ratios of around 5.5 waterjets tend to loss their efficient characteristics.
But like most rules and caveats it does not mean it is not feasible or advisable. Since we have used waterjets on a 50m catamaran running at only 22knots; the LD ratio was high, which helped. Also on low LD ratio hulls, like those windfarm catamarans waterjets are still used because their top speed is circa 30knots. So nothing is cast in stone…you select the best for you and your boat, regardless what sales data suggest. Horse for courses.
So below are curves of PC v speed of KaMeWa waterjets early data with a few spots and much later with many more from trials which confirms the early trends. KaMeWa is now Rolls Royce. You can see PC's reaching almost 0.80, which is very high indeed.
Also a more generic PC v speed of different propulsion types.
Does this helps?
