solidmesh
Discussion in 'Software' started by yipster, Nov 14, 2006.
  1. yipster
    yipster designer
  2. marshmat
    marshmat Senior Member
    Hi Yipster,
    The tutorial you found is for generating an analysis mesh to use with a CFD solver such as Ansys CFX or Fluent 6. SolidMesh is an experimental program for generating unstructured analysis grids, it's still in development. Not much relevance to Michlet, which does not make use of such a meshing engine.
  3. Leo Lazauskas
    Likes: 151, Points: 63, Legacy Rep: 2229
    Leo Lazauskas Senior Member
    Yes, and in fact that's exactly the sort of complexity that Michlet (and boundary integral methods in general) try to avoid. Despite what many people say, Michlet is *not* a CFD program.
  4. yipster
    yipster designer
    thanks for the reply's, was not sure what i was looking at with solidmesh
    can you point me to a Michlet tutorial
    i like to compare wave against friction drag on a long skinny cat hull
    where wave stays below friction (and lowers with increasing displacement speed?)
    edit: oops, found the Michlet html tutorials in the docs, easy yet complex enouch
      File size:
      35.7 KB
  5. marshmat
    yipster- you're familiar with Freeship? If not, it's easy to learn.... and it makes a perfect modeller and front-end processor for Michlet, in my experience it produces a virtually perfect Michlet input file every time. You still need to know how the in.mlt file is structured, but it makes the actual file generation almost too easy.
  6. yipster
    yipster designer
    thanks, made and saved a quik freeship cat hull ( odd stations bow first and hope good enough ) tryed loading as in,mlt in the michlet dir but not yet working, printing the manual, can try the other files tho, or win edit what? want my cristmas marvel to work and yes there are forums but since were talking...
    you cant look a given horse in the mouth they say but with a modern interface this winnder would be priceless ;P
  7. yipster
    yipster designer
    jaja yippy jee, michlet running :) i was starting a older version he said embarrast
