Note: This feature may not be available in some browsers.
Trying to fill existing tubes that are old and failing is a fundamentally bad idea. Things are going to continue to fall apart and it's just going to get uglier the longer it goes. While this is a RIB that has a real hull bottom, a lot of stiffness comes from the inflation of the tubes, it's the stretching of the tube in the length of the tube that makes them stiff. Even though you're adding something inside the hull, you aren't going to stiffen the hull in the same way as you would if it was inflated. If you use a higher density foam you might get there, but you're really a lot of weight when you do that. The best bet, although it's not cheap is to get new tubes. That probably isn't what you want to hear, but that's the best thing to do.
