Darbio
Junior Member
- Joined
- Jan 8, 2019
- Messages
- 15
- Reaction score
- Location
- Australia
Very much so. A HDPE collar would be great - just not sure how to make one...
Note: This feature may not be available in some browsers.
It is a shame that giant pool noodles don't exist.
Make you own honeycomb of jumbo noodles with pvc inserts, then cover that with fabric. If you leave the back end open it will be like one of those fancy rescue RIBs with hull that takes on water ballast at rest, then ejects it as it gets up to planning.
Being foam, along with multiple attachment points of layers of pvc, should create an very redundant structure. A honeycomb could have a unique angular look, and maybe a flat-top which might be more handy for setting things on than rounded air-tube. Maybe add a semi-ridge flat surface to the top along the sides.
Avon was the brand. It was a family of their higher end RIBs with deep Vee hulls intended for rough open water use.That’s an interesting thought! Any pics of the Rescue ribs you talk of? I don’t think I’ve ever seen them..
You could cut a length of the pipe in half and use the inside as a mould to glass up a tube in two halves, bend the inside half into place on the boat, then bend the outside one to that, join them together via a flange.I spoke to an engineer who told me it was pretty bendable. At 12mm I don’t think I could bend it myself but a fabricator should be able to.
Alas, at 12mm it would be too heavy. At 3mm it may be doable! Just to find some pipe of that diameter with that thickness.
Do you have any insights?
You could also take the tubes apart, clean the glue residue of the seams and reassemble by welding or new glue.
The simplest way to fabricate fiberglass tubes is to use XPS. Glue sheets to the desired thickness with epoxy, sand out the desired shape, laminate over with epoxy or xps safe poly resin, fair and paint.
One thing you have to understand, with fiberglass tubes there is no spring and give, you have to use fenders while docking. If those things are important to you then you have to use foam into flexible covers.
HDPE is heavy and can not really be glued to the bottom. I would not bother with it at all.
Fiberglass is double the weight of HDPE but that is not the most important thing.
