solid Iroko cabin trunk
Discussion in 'Wooden Boat Building and Restoration' started by John Dickie, May 14, 2020.
  1. John Dickie
    Likes: 4, Points: 8
    John Dickie Junior Member
    Hi Rumars, the plans appear to say 2&half inch #12 bronze screws
  2. John Dickie
    Likes: 4, Points: 8
    Hi Bajansailor, here's a photo. Doing deck seams with Jeffries Marin e Glue-plagued by bubbles.
    Rumars and bajansailor like this.
  3. Rumars
    Likes: 1,000, Points: 113, Legacy Rep: 39
    Rumars Senior Member
    Nice boat. Interesting decking pattern. The bubbles in Jeffries can be smoothed out with a big soldering iron.
    I would laminate the sides with 6-8mm veneers. Then I would probably deviate from the plans and glue the sides to the carlins, beside screwing it to them and a toepiece outside.
    fallguy likes this.
  4. John Dickie
    Likes: 4, Points: 8
    Thanks all for the unput. I will steam bend with a backing strsp and scarf afterwards. The curve is 270mm,as I changed the trunk curvature to match the deck plank curvature. Wish me luck:)
  5. Rumars
    I hope it all goes well and you post pictures.
  6. John Dickie
    Likes: 4, Points: 8
    Will do, but will be a month or so. 10days and a third of the way caulking the deck.....
  7. Rumars
    You may want to present your project to the good people at forum.woodenboat.com There are people there who did (and some still do) this kind of thing for a living.
  8. John Dickie
    Likes: 4, Points: 8
  9. John Dickie
    Likes: 4, Points: 8
    Timber to be bent in foreground, bending jig centre, steambox behind, leverage at right
  10. John Dickie
    Likes: 4, Points: 8
    Timber with backing strap on bending jig
  11. John Dickie
    Likes: 4, Points: 8
    Making rectangular Spruce main mast and Douglas Fir Mizzen.This is looking down on the mast step of a 35ft steel ketch:its a 35mm thick "teak" plank bolted to 8mm steel T step.Its looking a bit puny to me.I would appreciate any opinions.
    bajansailor and fallguy like this.
  12. Rumars
    The plank is mostly there to keep the mastfoot from sliding around when stepped. Once loaded all the compression forces go into the steel. I would recommend some kind of weephole(s) so any moisture can escape. If you want it more sturdy weld a box with outside gusstes to the step instead of the plank.
  13. gonzo
    Likes: 1,555, Points: 123, Legacy Rep: 2031
    That is a really nice job. The metric tape will confuse many people on this side of the ocean ;)
    bajansailor likes this.
  14. John Dickie
    Likes: 4, Points: 8
    Thanks Rumars,Gonzo,maybe I'm over-thinking the forces on the mast heel.I was just suprised how long 13.6m is,and just how heavy a 102kg bare pole is.
    John
  15. fallguy
    Likes: 1,586, Points: 123, Legacy Rep: 10
    fallguy Senior Member
    It is really beautiful. I have little to offer here beyond marveling at the work. Keep giving us little dog treats of pictures. Thanks.
