Solar battery charger
Discussion in 'OnBoard Electronics & Controls' started by Vulkyn, May 28, 2017.
  1. Vulkyn
    Likes: 46, Points: 28, Legacy Rep: 654
    Vulkyn Senior Member
    Ok so question for electronics guru :D
    Got my hands on an old cell charger, thinking myself smart i get the voltmeter (which i have no idea how to use btw) try to set it up for DC and measure the output.
    It's 43 degrees in the sun today, so got a reading of -18.97 volts (i think i switched something :S shouldn't be negative) and current was 1 (i think so took pictures so help me please :D)
    So my questions:
    1- Would this trickle charge be able to help charge my battery? Or is it enough to just keep battery from losing charge.
    2- Would i just plug it in the v12 socket and it will go back to battery or do i need a direct connection to battery? (get a socket and attach directly to terminals)
    3- Would be safe if I leave the batteries for extended time to have the solar panel connected (not on the boat of course)
    4- Did i measure the current or is that me making a fool of myself yet again?
    5- I have a secondary battery which i wanted to have as backup and if the above idea works I can make a socket and just have the solar panel charge it directly and if need be i switch batteries knowing my backup will be have some charge in it (or am i day dreaming here?)
    Thanks for the help in advance folks :D
  2. ondarvr
    Likes: 699, Points: 113, Legacy Rep: 506
    ondarvr Senior Member
    That charger would have a tough time charging your cell phone battery, it would do almost nothing on a full sized battery.
  3. Vulkyn
    Thanks ondarvr, that would be because of weak amp output right ? if so and i would like to pursue the solar chargers what output would i need?
  4. CDK
    CDK retired engineer
    To maintain the charge level of your battery without electronics, the (amorphous) solar panel should be able to provide a short circuit current of approx. 1/40 of the battery capacity. That is a rule of thumb for Western Europe, in Egypt it should probably be 1/50.
    So for a 80Ah battery the solar charger should have a current of approx 2 A. The toy charger you present here can supply 20 mA, not quite enough.
    The picture showing a current of 1.00 is meaningless because you have the selector on 20 Amps but used the mA input terminal.
  5. gonzo
    Likes: 2,322, Points: 123, Legacy Rep: 2031
    It may not charge a battery, but is probably enough to keep it from discharging.
  6. Vulkyn
    Thanks :) i think i did something stupid and burned the current dial on the voltmeter .... everything else is reading fine but the current is giving zero on everything (i think i shorted it on the battery says 20 A max and i had it on current when i was checking volt) couldn't find a fuse inside it so meh ... (guess i need to learn some stuff the hard way...)
    If it can reduce battery charge loss then that would be perfect, i have a regular battery so in theory if I plug the charger in and leave it for 2-3 month would be better off then to leave it to discharge.
  7. ondarvr
    Your charger can supply 12mA at best, this would be when it was new (as they age they lose efficiency), at noon on a cloudless day and at the time of year when the sun is directly overhead, any other time it will supply less or nothing. You need about 2 amps to actually do any charging or maintaining.
    Will it do something...sort of.....will it be of any value....not really.
  8. Vulkyn
    Well its worth looking at some sort of alternative solar charging solution to keep battery healthy. In Egypt we have plenty of sun all year round.
    Appreciate the feedback !
  9. ondarvr
    Just scale up until you can get enough amps to do the job, plus get a charge/voltage controller so you can charge at the correct voltage for the battery type. Solar can work great to keep a battery charged.
    Vulkyn likes this.
  10. BertKu
    Likes: 47, Points: 58, Legacy Rep: 223
    BertKu Senior Member
    Hi Vulkyn, you probably have figured it already out that you blew the internal fuse. If not yet fixed, open the meter and replace the normal 10 Ampere fuse of the same kind. But be careful not to unscrew too many screws, otherwise you will probably battle to put all the parts back again. Bert
  11. Vulkyn
    I did it seems my voltemeter has 2 amp settings, fused for 10A and unfused for 20A (i think it was plugged as unfused). The fuse seems fine as all the other readings are working except amp.
    Will probably need another voltemer to see if i burned something on it lol
  12. Vulkyn
    So had an interesting meeting today regarding the solar panels with a specialized electronics store.
    They recommended a 20 cm panel that will produce around 1 Amp, fit it a batter controller for regulation and overcharge protection in a water proof cover. I can then attach a marine 12 V socket with aligator clamp on the assembly so I can remove it with me after boating.
    They will send data sheet for the equipment and i will take it from there :)
  13. Vulkyn
    So couple of month later ... i have built my own little solar panel system to charge my batteries :D
    Opted for a 20 watt / 1.14 amp panel with a charge controller which i fitted in a water proof box and used silicon to make sure no water seeps in (did a full hose check!)
    Used lousy cheap clamps cause i didnt find anything good and did my first trials today and it was lovely. The idea is not for a quick charge but rather i can leave the battery to slow charge and the controller trickles / stops so when i come back at any time i have the battery charged and ready.
    Thanks for the guidance folks :)
    hoytedow likes this.
  14. Vulkyn
    I did sir thank you :)
  15. ondarvr
    What voltage are you seeing at the battery with the panel on full sun.
    1. CRAMAR
    2. Atilan
    3. brian eiland
    4. ProBoat
    5. Vulkyn
    6. Jonny3777
    7. Vronsky
    8. BertKu
    9. L'eau.Life
    10. markstrimaran
