Sodebo Ultim3 Jules Verne Record attempt 2025-2026.
Discussion in 'Sailboats' started by philSweet, Dec 23, 2025.
  1. philSweet
    Likes: 644, Points: 113, Legacy Rep: 1082
    philSweet Senior Member
    BlueBell likes this.
  2. wet feet
    Likes: 627, Points: 113, Legacy Rep: 124
    wet feet Senior Member
  3. philSweet
    Sodebo Ultim 3 and its crew have set a new outright record from Ushant to the equator of 4 days, 4 hours, 2 minutes, and 25 seconds. The previous record was set by Spindrift 2 in 2019. Sodebo beat the old record by 15 hours and 54 minutes. They are on track to pip the current record from Ushant to Cape Hope set by Rothchild in 2023.
  4. philSweet
    Looks like Sodebo Ultim 3 beat Gitana's Record to Cape Hope by something over 13 hours.
  5. brian eiland
    Likes: 267, Points: 93, Legacy Rep: 1903
    brian eiland Senior Member
    I hope she doesn't suffer any race eliminating damage or structure failures. I'll really like to see her win that trophy,..at least once.
  6. philSweet
    They seem to be operating quite conservatively - at least from a weather routing perspective. There have been frequent mentions that they are out-performing their polars when the sea state is big and the crew says they can handle bigger seas. I suspect it will be really close at the end. Idec had a magical run across the Southern Ocean in 2017; and Sodebo has given back about 1200 nm to her since Cape Hope. Sodebo will probable continue to lose a little ground this week. In 2017, Idec sailed from the middle of the South Atlantic over to east of New Zealand on one board. Sodebo has gybed 29 times so far and is only 2/3 the way there.
  7. philSweet
    Good video showing a lot more of the boat's interior and general arrangement. They are still a bit ahead of record pace but not enough to be comfortable. Idec had a great run in the North Atlantic to the line. I think Sodebo needs better than average conditions to set a new mark. They currently have a five knot advantage over what Idec was doing, so are drawing away a little. Crew looks a bit punchy.
  8. brian eiland
    I forgot how to translate to english,..help
  9. Dolfiman
    Likes: 701, Points: 113
    Dolfiman Senior Member
  10. Dolfiman
  11. wet feet
    They did it! From what I saw on the youtube livestream earlier,the boat looked a little worse for wear but was still moving at a good pace.I read that they had lost part of the rudder turret fairing and the helicopter shots revealed that the underside of the starboard fairing on the aft beam had been taken off over part of it's width.Same incident perhaps?
    The entire crew from designers,builders,sailmakers and sailors deserve congratulations and Sodebo made it all possible.Well done everybody!
  12. philSweet
    I think the rudder faring came off in Ingrid about 800nm from the line. Don't know about the cross-member fairing but Ingrid was the biggest seas they encountered.
  13. philSweet
    And as a footnote, Famous Project crossed the line today after a whole lot of sail and rig troubles, setting the first mark for female unsupported RTW trip on the old Idec.
