snowmobile engine marine convert?
Discussion in 'DIY Marinizing' started by racing fan, Mar 20, 2011.
  1. Frosty
    Frosty Previous Member
    The prop size would be like the drive belt width on your snowmobile.
    Would'nt get far if the belt was only 1 foot wide!! lots of slip.
  2. racing fan
    Likes: 2, Points: 0, Legacy Rep: 35
    racing fan Senior Member
    yea well i think of somthin i guess thanks guys
  3. claydog
    Likes: 2, Points: 8, Legacy Rep: 69
    claydog Junior Member
    Frosty, you were talking about the track being a foot wide and not the drive belt weren't you? Traction (slip) on a snowmobile is mostly governed by lug height and stud count, track length and width effect "floatation" more than traction.
    FYI, common snowmobile tracks range from 13" to 16" wide X 120" to 162" long, drive belts range from 1.5" to 2" wide.
  4. powerabout
    powerabout Senior Member
    Not neccesarily, oil is still pumped to the top bearing of an outboard from low points in the engine you will need to sort that out.
  5. racing fan
    in two stroke motors the gas/oil mix travels to all the parts that need oil but if you flip the motor and rotate the carb to get it to run you will have a prob but if you managed to get a fuel injected one or a fuel pump you will be able to sort that problem out
