Small trimarans under 20'
Discussion in 'Multihulls' started by Doug Lord, Jun 24, 2012.
  1. Doug Lord
    Doug Lord Flight Ready
    It appears to be a "by invitation only" group-is that right?
  2. Corley
    Corley epoxy coated
    It's a closed group probably set that way to keep the spammers under control. You should be able to join if you have a Facebook account.
    Doug Lord likes this.
  3. Doug Lord
    Oh, well--no facebook for me......
  4. Corley
    Corley epoxy coated
  5. Doug Lord
    Considering how much she cost that's a hell of a good deal. I wonder if they're building another proto from the tooling? As far as I know they never did put the big rig Dr. Sam designed on the boat-too bad. As is she takes off in about 7 knots of wind. Dr. Sam and I talked a lot about light air takeoff.......
    Corley likes this.
  6. Cholsson
    Likes: 29, Points: 18, Legacy Rep: 14
    Cholsson Junior Member
    Just want to share my short video from the weekend. It has been the best and warmest summer since 200 year in Sweden. Ok like a regular day in Florida I guess. Anyway, good sailing with great wind. Speed about 10-12 knot upwind and 12-17 knot downwind.
    Gary Baigent and Doug Lord like this.
  7. Doug Lord
    Breathtakingly beautiful! And I like the music, too.....
    Cholsson likes this.
  8. Cholsson
    Thanks! Best day ever :)
  9. Lurch723
    Likes: 15, Points: 8, Legacy Rep: 10
    Lurch723 Junior Member
    Yeh looks really good and you look very comfortable too!
  10. revintage
    Likes: 48, Points: 28, Legacy Rep: 10
    revintage Senior Member
    Cholson kindly offered me the second A-cat hull, that was left from his trimaran build. Intend to build a close to square 18ft foiling tri. At first without foils and with half a windsurfingboard as ama on each side, later with either T, V or surface piercing foils. Without making any calculations I am sure a 100x2mm, or even a 90x2mm, round aluminium tube will be more than sufficient as main beam. Anyway something to do and lay your hands on, to make it through the long Swedish winter.
  11. Doug Lord
    Lars-sounds like a great project-good luck! Would it be worth searching for a used carbon tube-mast or?- instead of an aluminum tube?
  12. revintage
    Looking for an A-cat mast, carbon or alu, I don´t care. I like Doug Halsey´s intelligent low budget concept.
  13. Doug Lord
    Osprey-18' X 22' wide(foil tip to foil tip), takesoff in 7 kts wind with small rig shown below. Designed by Dr. Sam Bradfield using his foil system which can provide all the RM for the boat with substantial windward foil downforce-automatically.
  14. Gary Baigent
    Gary Baigent Senior Member
    What is the point of posting the extremely expensive Bradfield foiler when an enthusiast is intent on building a small foiler out of obtained hull parts? How about, instead of living/dreaming/posting vicariously, you actually build a 20 foot foiler of your own?
  15. Doug Lord
    The "extremely expensive Bradfield foiler" is available NOW for $19,000US-which is less than a Moth!! But the main purpose of posting about it is to possibly spark the imagination and help any one interested in a similar 18' foiler to see one way of doing it. Dr. Sam Bradfield was one of the greatest foiler pioneers in history and his designs are worthy of consideration and study by anyone seriously interested in a foiling multihull.
    This boat ain't no frog-it actually gets up on foils and flies and with the bigger rig Dr. Sam intended for it she would fly in a 5 knot breeze.
