Small trimarans under 20'
Discussion in 'Multihulls' started by Doug Lord, Jun 24, 2012.
  1. Doug Lord
    Doug Lord Flight Ready
    I already have a trailer and it cost $600* in 2001 or 2. But during this project(now converted to a smaller boat from the tri) it occured to me that you can get flatbead trailers here fairly inexpensively. And I have a lot of carbon and glass tubes here so after seeing "dollies" costing more than my trailer did it occurred to me that I could get some wheels and build my own dolly for around $300US. I want to have my trailer converted so that it has a flat bed and a fold up "gate" at the back and some sort of "risers" so the dolly with the boat on it doesn't have to take road loads. That will be the almost perfect solution for the new little boat as it would be for the tri. Anybody handy with epoxy/carbon/glass can build a small dolly for far less than they are being sold for now.
    *Now that trailer would be around $1100US(guess) and would handle a 300lb boat easily(600lb capacity).
  2. Brian2009
    Brian2009 Junior Member
  3. mydauphin
    Likes: 54, Points: 48, Legacy Rep: 575
    mydauphin Senior Member
    You can buy small Trailers cheap at northern tools or harbour freight, then modify them. However they are cheap steel and not galvanized so proper washing and painting wouldn't keep rust away.
    This time of year if you can take the heat and humidity , the mosquitoes will get you. I stay in the AC and blog.
  4. Richard Woods
    Richard Woods Woods Designs
    Brian2009
    Thank you for posting the link to my Strike 18. However I think my Strike 15 is nearer the under 20ft racing trimaran Doug is interested in.
    You can see more here
    http://sailingcatamarans.com/Strike 15.htm
    Being built now, in 4mm ply and epoxy, the prototype should be sailing later this year.
    So far the plywood, timber, epoxy, glass and screws for the main hull have cost me under CAN500 (so say USD500). I probably have enough epoxy and glass to build the outriggers as well. Materials in the USA are much cheaper than in Canada.
    The main hull before decking, but with all bulkheads and daggerboard case fitted, should weigh 30lbs and have taken under 30 hours to build. I'll know for sure next week
    www.sailingcatamarans.com
  5. Doug Lord
    Here is are a couple of beautiful pictures of this trimaran-be sure to click on it, expand it and click once again:
  6. redreuben
    redreuben redreuben
    Transporting Multihulls
    Miss Cindy takes car topping to new levels !
  7. redreuben
    redreuben redreuben
    OOps wrong thread !
  8. SpiritWolf15x
    Likes: 1, Points: 18, Legacy Rep: 15
    SpiritWolf15x Senior Member
    That is quite possibly the most awesome thing I've ever seen!
  9. SpiritWolf15x
  10. Doug Lord
  11. Doug Lord
  12. Doug Lord
  13. Doug Lord
  14. Ilan Voyager
    Likes: 238, Points: 63, Legacy Rep: 758
    Ilan Voyager Senior Member
    Doug, there are all obsolete day sailers, with no perfs in front of a god cat, and expensive to build. No interest to invest a buck in such boats. The above videos show all the same thing; a cruel lack of volume of the amas (and "potatoes bag sails" for some).
    Good amas on a tri are about 220% of the DISPLACEMENT, with rudders on the amas, that means boat and crew on a small tri. So I leave you imagine the size of the amas...as big as the central hull. In France we learned the lesson in the years 85-90 with the F40, and after no tri was designed as the old ones. All oceanic race tris can fly on one hull, even 100 feet long, that's an absolute requisite. Look also at the hulls now: very simple, high prismatic coeff, almost no rocker.
    All these boats are 20 years obsolete, and far too expensive to build. I do not see any advantage compared to a 18 feet cat with comfortable wings...
  15. Doug Lord
    The statistics have value to anyone designing a small tri. I'd hardly call the Weta an obsolete simple daysailer since it is one of the most successful production trimarans under 20' ever.
    But I agree that if I build another small tri it will be a beachcat killer. Small tri's have a bad rap for being slower than equivalent length beachcats-it doesn't have to be so.
