Small Steam Boat
Discussion in 'Boatbuilding' started by rolphill, Aug 30, 2024.
  1. BlueBell
    Likes: 1,221, Points: 113
    You may want to try three blades before machining that hub.
    If you make the transom joint articulating you can also make for steering.
    But it gets complicated fast...
  2. jehardiman
    Likes: 1,446, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    No, because you have the torque in a steam engine, you want the largest, slowest turning prop you can fit...the Wageningen B-2.35 was not a random selection, but an optimal one. It would be better to fit a weed cage than a less effective prop.
  3. Rumars
    Likes: 1,319, Points: 113, Legacy Rep: 39
    Rumars Senior Member
    It is as you say, I just don't see the benefits for this particular boat. It is much simpler to speed up the prop via a chain or belt drive and make use of the wide availability of cheap plastic trolling motor props. This also solves some installation problems like excessive shaft angle.
    An option I didn't mention is to make a steam outboard. A short steam hose section will solve the issue of having the boiler in the boat and the engine on the transom.
  4. jehardiman
    While the prop shown is obviously not the correct one...(lots to comment about here)...this is much closer to the correct one than other models. While I don't support his options, I do support his selections.
  5. Rumars
    The "ideal" prop represents a problem. To achieve 5mph with 1/2hp at 300rpm a ~900lbs boat (he wants to take the family) needs a 20-24" x 24" prop. If shaft angle is to stay under 15° the engine and boiler end up somewhere in the first third of the boat. Weight distribution aside this invites ergonomy problems.
    Everything can be solved of course, but is it worth the complications?
  6. rolphill
    Likes: 0, Points: 3
    rolphill Junior Member
    Where did you get these numbers? I haven't really found any info on how to calculate this kind of thing, so I was just looking at other steam boats for inspiration.
  7. Rumars
    You should buy Gerr's Propeller Handbook but online calculators should give you similar results.
    Displacement (weight) is an important factor, I made a mistake writing my previous post (corrected, was thinking in kg's). This kind of boat is usually rated around 900lbs, wich is realistic considering the hull weight, power plant, essential gear and 3-4 people.
    The hull form with its immersed transom is what it is, can't change that.
  8. rolphill
    Likes: 0, Points: 3
    I managed to get a copy of the handbook, and I'm reading through it. The displacement speed formula gives me an estimated speed of 3 knots, which is about what my ideal speed goal was.
    In the meantime, I got new wood for the gunnels, and for whatever reason it's much more flexible. I've got one on already. I also made 2 more blades, and started working on the stern tube. I printed a 4 blade hub, and am working on printing a shroud for it. The stern tube will use a standard mechanical shaft seal, and a PLA shaft bearing which doubles as the thrust bearing. The shaft will be 12mm stainless steel, with a keyway. PLA is hard and slippery, so it makes good bearings as long as it doesn't heat up.
    Screenshot 2024-09-16 080408.png Screenshot 2024-09-18 070144.png Screenshot 2024-09-16 080514.png IMG_1511.jpg IMG_1510.jpg
  9. gonzo
    Likes: 2,239, Points: 123, Legacy Rep: 2031
    What is the compression strenght? Also, the bearing will get hot unless there is some kind of cooling, which would be rather complicated.
  10. Rumars
    That bushing will not act as a thrust bearing. If you don't want to use commercial roller bearings rated for axial loads, machine a traditional thrust block and insure lubrication.
  11. gonzo
