I spent the last year or so building a steam engine with the intent of building a land vehicle. However after several bench runs, I decided that the boiler I built is a bit too temperamental and more of a handful to operate than I was expecting, at least without adding any automation. So I decided I want to put it in a boat instead.
Now, last year I built a tiny 10ft sailing dinghy, but the family obviously wouldn't fit in it, so it's nigh impossible to get several hours out on the water with it. However, my FIL gave us his old 14ft aluminum v-hull. All the wood was rotted, and normally it would've been easier to ditch this boat and find one that was in better shape, but this boat has a big advantage many of you will understand:
This is my wife's childhood fishing boat, so she has a lot of nostalgia attached to it. This translates to significant leeway in time and budget to get it back on the water.
It was pretty rough, but it held water without leaks, so it was time to start taking it apart.
I took a wire wheel to the inside, and got all the loose paint off. Most of the paint was still stuck fast though, so I left it and started putting a coat of bonding primer on.
That's about as far as I've got on the hull itself. As far as the engine goes:
If you're curious, the engine and boiler is better documented here:
Boiler for putting around in small dinghy. https://www.homemodelenginemachinist.com/threads/boiler-for-putting-around-in-small-dinghy.35874/
Trackless Locomotive Build https://www.homemodelenginemachinist.com/threads/trackless-locomotive-build.36176/
I have a bit of a unique situation where I have access to a large CNC at work and a small pile of scrap metal, but at home I have little hobby money and little free time. This results in unique situations like this week, where I decided tosave $20make a propeller to match my engine.
The math says my engine will make about half a horsepower, so I needed an efficient low speed propeller. My propeller requirements are very similar to human powered kayaks and the like, and I looked at existing rc plane props, but I couldn't find anything really ideal. So I finally decided to machine my own propeller. I targeted 5mph at 300rpm, and used some propeller generator I found online to come up with this 12in x 20in design.
Machining this was a bit of a pain.
But it eventually came together. I still have to sand everything smooth yet and round the tips.
I'm not a fan of the hub though, I feel like it's going to have a lot of drag in the water. I think I might try 3d printing a small shroud to enclose all those angular surfaces.
Given the lack of power, and the fat hull shape, I'll be happy if I reach 3mph putting around the local lake. My stretch goal is to build a deck on the hull and make a little decorative(featherweight) cabin to make it look like a mini tugboat. Then I'll probably work on making a bigger boiler so I can go faster, as the engine could easily make 2+ hp with enough steam.
Besides working on the hull itself, the next thing to figure out is the stern tube. Obviously this hull originally had an outboard, but at least the transom is flat, so I don't need to conform to a weird angle. The major design consideration for the stern tube / stuffing is going to be minimum friction, as I don't have any power to spare.
I'd like to get the boat in the water before winter, but probably with a regular outboard. Then I have all winter to figure out the steam engine installation.
