I built an 8' boat . . . it is basically a pram dinghy . . . fiberglass over foam core. I didn't know enough at the time, so it could have come out better.
8 feet is not much in terms of a size . . . Mercury built a small 'speed boat' often called a Mouse boat, as I believe they were featured at Disney World . . .
It sounds like this is what you may be after.
If you want to make a mold for re-use, then you will probably want to follow a 'plug-mold-part' process. I used this process when I made an extended swim platform for one of my boats. (there is a thread on here with all the details - just search for 'custom extended swim platform' )
The 'Plug' will be an exact size/shape of the boat, usually made out of foam and finished with epoxy or similar material to get a nice smooth/shiny surface. From the Plug, you can then make the mold . . . usually starting with tooling gelcoat and then building up layers of fiberglass. A re-usable mold will need some structural reinforcement on the outside. I would recommend viewing boat factory tour videos on Youtube to get a visual of the process and what the molds generally look like.
You will probably have 2 molds . . . 'hull' and 'cap'. They usually join at the rubrail. This may be what you are talking about with the aluminum, but I'm not sure that will be the right approach. Usually the hull/cap joint is a shoe-box style for power boats. My sailboat has an external flange joint, but you don't see those too much with powerboats.
As for materials . . . Vinyl Ester resin . . . biaxial cloth . . . (1708 and 1808 for multi directional strength) . . . foam cores for weight savings & strength.
Your boat should have positive flotation so that it is USCG compliant. So think about that. Boats sold in the USA require a Hull ID Number (HIN) . In small quantities, you can/should get the HIN from the local state agency that is in charge of watercraft. Each state has their own 'MIC code' which is the HIN pre-fix. I got my HIN for the boat I built from the nice folks at the Massachusetts Environmental Law Police.
Got any sketches/drawings of what you are planning to build ? . . . it should help with further replies and guidance.
Oh, and go get some money . . . I would think $10,000 would be a good starting point, but it may lead to more.
