hi everyone!
thank you all for your input! I'll get back to you for some of this stuff, meanwhile I have an issue I would like some to hear your opinion about.
I have a bunch of hatches on my toons (for inspection, storage etc). At this moment I have recycled the plywood cutout as hatch: it was available, it sits flush, has a little hole for air circulation, buut is very much not waterproof. Which means that if I get a big wave onboard (while on the water) or some rain (because I have a leak in the walls/roof, or I have failed/forgot to properly close the curtains - happened a couple of times already) of course I get some water inside... what to do:
1. leave as it is: I have reserve bouyancy, a pump, and if water gets in I can get it out and let it dry;
2. seal the hatches with a waterproof cover, maybe I could just screw on a cover with some kind of rubber band as seal, and keep an electric screwdriver onboard if I need to open it up - easy enough, cheap and effective; or buy and fit a regular waterproof hatch;
3. use some hatch design that prevents or limit water intake (in case of waves or rain), maybe I could just build a raised border around the hole, like 1-2cm, and design the cover to sit on top of that, so any splash water would just flow around the deck, and I cold add scuppers to let it drain outwards by itself; it wont sit flush, so it is more annoying if I want to move/place stuff on the deck over the hatch.
what do you think?
bonus question: do you know anyone that makes decent electric motors that works with external batteries? All I can find are either motors with embedded battery, made mostly for tenders I think, which are kinda expensive (in the thousands, mostly for the battery I think), or cheap chinese devices, which are veeery cheap (200-500E), powerful enough, but fell too cheap to be actually reliable. I would like something with a top price of 1000-2000E (but ideally around 500-750), 48V-72V, and around 2-8Kw electric power (I would cruise at 2-4Kw because that's what the panels allows me for unlimited range, but a little more power is good to have "just in case").
thanks!
D
