Small RIB boat with HDPE hull
Discussion in 'Boat Design' started by rioandcopa, Apr 20, 2023.
  1. rioandcopa
    Likes: 1, Points: 1
    rioandcopa Junior Member
    Hi.
    I think whaly boats have hard plastic ribs, not inflatable, thanks.
  2. rioandcopa
    Likes: 1, Points: 1
  3. Hank Rosendal
    Likes: 3, Points: 3, Legacy Rep: 30
    Hank Rosendal not old enough for some things, too old for others
    About 20 years ago, we made such HDPE dinghy, 3,3 mt long when our workshop was not very busy. We used some leftover tubes (from memory 350 mm/ 14" in diameter), 8 mm bottom, and the stern for outboard 10 mm, and reinforced with alu square tube. It was very heavy, 2 people could not lift it, 4 of us just could, so i guess well over 150 kg, or 300 lbs, that was without an engine. We put a 15 Hp outboard on it, and with 2 up, could not get it on a plane. BUT...... it was very strong, and I would say indestructible. The dinghy floor and everything else was very slippery.
    I would not repeat that exercise unless I wanted a low speed workhorse.
    comfisherman likes this.
  4. BW Olivier
    BW Olivier New Member
    Hi Mac,
    We're a HDPE builder from The Netherlands, have a look on www.blackworkboats.nl .
    We've made several small boats in HDPE, and we also want to build a HDPE Rib in the future.
    We're sure this could be a great combination, and also possible to keep it lightweight.
    You can also contact us on info@blackworkboats.nl or call/ whatsapp us on: +31 85 06 006 89.
    Looking forward to your response, and what you're exactly looking for.
    Regards, Olivier from Black Workboats
  5. CT249
    Likes: 266, Points: 83, Legacy Rep: 215
    CT249 Senior Member
    I know it's an old thread but I have a PE RIB; a Walker Bay Genesis. It's not heavy nor particularly flexy, but it does have excellent abrasion resistance. Goes well with a Tohatsu 9.8 2 stroke. Sadly they seem to now only make bigger boats where GRP works well.
  6. Ufuk_Atalar
    Ufuk_Atalar New Member
  7. yoolwinmarine
    yoolwinmarine New Member
    At present rib boat mainly produce in fiberglass hull or aluminum hull.
    Because when boat run fast in the sea, fiberglass hull and aluminum hull rib boat the impact is much better than HDPE.
    You can check some boat popular models below.
    www.yoolwinmarine.com
    RIB boat size from 10ft to 35ft
  8. yoolwinmarine
    China market produce with HDPE boat. Used for different fields, normally for work boats/ patrol/ military and army boats.
    Aluminum rib boat also be ideal choice for these usages.
    www.yoolwinboat.com
  9. Barry
    Likes: 645, Points: 113, Legacy Rep: 158
    Barry Senior Member
    Check out Bullfrog Boats, Anacortes.
