jakeeeef
Senior Member
- Joined
- Sep 10, 2009
- Messages
- 202
- Reaction score
- 37
- Location
- Hamble
I'm looking to make or source/ get built, or at least research a small, hydrodynamically efficient lightweight liftable stern drive.
Initially a single prototype, but potentially more later.
I'm researching what is/ has been on the market.
It will need to handle up to approx 5 hp.
For my purposes, it would need to be:
Transom mounted
Driven by a shaft coming in horizontally at the top
Lift by rotating 180 degrees about that shaft on a simple pair of lubricated plates.
So when in lifted position the prop will be out of the water and the leg will be vertically upwards with the prop in the air.
It will be locked in either the up or down position by simple sprung pins through the plates.
The pins and the lifting (canting) could all be done remotely by simple lines, cleats and turning blocks.
Power will come in horizontally at the top, bevel gear down to the vertical leg shaft, bevel gear again to the prop.
Where the power comes in at the top the shaft might need a small flexible section, so that the trim can be altered, but such trim adjustment would not need to be conducted on the move or on the water.
The lower bevel gear will need to be as compact as possible for hydrodynamic efficiency as it's a low power vessel hoping for good performance.
It will drive a relatively slow moving, very high aspect ratio two bladed prop.
Rudder will be integrated into a section of the (teardrop profile) leg, and actuated by simple hydraulics, so that it is only connected to the hull by flexible pipes, and therefore does not need to be integrated mechanically into the lifting/ lowering mechanism.
I'm guessing nothing like this is or has been in production, as it's a new concept that I need it for, but has anyone seen anything LIKE it?
Many thanks
Jake.
Transom mounted
Many thanks
Jake.
