Fairing filler......
Discussion in 'Fiberglass and Composite Boat Building' started by Roly, May 24, 2006.
  1. Roly
    Likes: 23, Points: 18, Legacy Rep: 222
    Roly Senior Member
    There is always the easy way to do things, and I gotta get this right as it could turn into a major time consumer.
    To those who know..........been there done that.......have the "force"
    Microspheres + aerosil---411
    Microballoons + aerosil---407
    Microlite + aerosil---410
    I have studied the west systems site but if you seal the faired finish with neat epoxy there seem to be little advantage except price. 410 is not recommended under dark colours, hard chines or thick as it is soft.
    How is the trowelability of 411 relative to 407?
    I am keen to get a good finish.
  2. SailDesign
    Likes: 197, Points: 73, Legacy Rep: 650
  3. bobsyachts
    bobsyachts Project Management
    when fairing use Awlgrip or international much better for sanding or even Hempel which is a little cheaper.
  4. Roly
    Roly Senior Member
    Thanks for your comments--Awlfair is not available here so it is a "mix my own
    scenario". Also, I can save money for elsewhere! :)
    Just can't see the advantage of using 407 phenolic MB's, as they are 4 times the $'s. Guess I will stick with 411(MicroSpheres) + 10% aerosil.
  5. yokebutt
    yokebutt Boatbuilder
    Roly,
    For fairing I really like using Q-cell (very easy sanding, and the glass balloons are nor suceptible to heat) and as little fumed silica as I can get away with without sagging.
    Yoke.
  6. Roly
    Roly Senior Member
    Thanks Yoke. I actually thought microsheres (411) was actually part Q-cell and colloidal silica?
    This was from the Baltek site.
    What is the difference between M.S's, glass bubbles and Q cell??:confused:
  7. lprimina
    Likes: 1, Points: 0, Legacy Rep: 35
    lprimina Senior Member
    Steve is right use Awl fair, you can get it shipped to you.. The money you save with cheaper means is wasted on time and energy plus the easier sanding means less mistakes. I cant say anything about Q-Cell I havent used it.
    Ben
  8. JR-Shine
    Likes: 4, Points: 18, Legacy Rep: 54
    JR-Shine SHINE
    For pre made epoxy fairing - Quickfair by System Three
    For "mix your own" - 4 parts Microballoons (phenolic) to 1 part silica by weight.
    The Quick Fair is better and you can sand it with a machine in 4 hours - that alone makes mixing your own no longer worth while.
    Joel
    boatbuildercentral.com
  9. yokebutt
    Not too crazy about phenolic balloons, harder to sand and also more difficult to hide due to the dark color.
    Fumed silica has the curious quality of making putties thixotropic and much easier to shape accurately, but it improves the abrasion resistance a lot too.
    Yoke.
    1. CaptTator
    2. Bigtalljv
    3. Scuff
    4. fallguy
    7. burke
    8. midcap
    9. JINLEE
    10. nevilleh
