Narrow, low freeboard, enough sealed buoyancy to not be a sub, shallow long steel plate keel ~30mm x 1m, shaped, which unbolts, water ballast, buoyant bows, foot and hand rudder methods, very strong rudder assembly, short mast, mast keel stepped, backstay, boom roller reefing or 2 different sized mains, small jib, big kite (for lulls), seat, windscreen, bailing system, big enough interior for not being jammed up in a bulky dry suit, internal controls from sitting position inside, thermos flask holder, no need for camping stowage so lots of sealed buoyancy, small shelf or hole/pocket for GPS, EPIRB, torch, etc.
No foils or moving boards, everything kept simple and strong and mostly light.
What measures you must take to avoid the need for a drysuit depends on why you need it in the first place. Where I sail, the water is cold enough that exposure during and after a capsize could kill me through hypothermia pretty much year round. So I would need a boat that keeps me dry throughout a capsize and can be righted without clambering round outside. Whether you need that or not makes a big difference to the weight of the hull. A windscreen would not abolish the need for protective clothing for me, but if you sail in waters warm enough, it may do so for you.
Let's say narrow translates to 1 metre beam. That might move your centre of buoyancy by up to 0.3 metres. The shallow keel would need to be quite heavy to move the centre of gravity down to the waterline, but assume that for the best case, and to simplify a back of the envelope calculation. Two crew, steel keel and water ballast might add up to 300 kg, exerting a force of 2943 Newton on a lever arm of 0.3 m for a righting moment of 883 Nm. You wanted to sit side by side, not hiking out, so I assume the crew's weight doesn't shift.
You have not shown any interest in non-heeling rigs, and seeing that I have only ever seen them in experimental boats and not one account of long-term experience using such a rig in everyday sailing, I guess that is for people who like to experiment. (I include kites here because they are still quite experimental on boats. Not the flying, but the launch and retrieval.)
But if you choose a rig that heels the boat, you really need appropriate righting moment. Reefing is no substitute. To see why, think of how, in a steady state, the forces from all the bits of the boat in the water and all the bits in the air must exactly balance. One consequence is that if you convert the lift to drag ratios into the corresponding drag angles, then the course to the apparent wind is always the sum of the drag angles. It follows that the closest course you can hold to the apparent wind is defined by the drag angles that correspond to your best lift to drag ratios.
Let's say that your rig and your foils can get a lift to drag ratio of 8 to 1. But then there is the aero drag of your hull. Let's say that is
1, so the overall lift to drag ratio is 8 to (1+
1), or 4 to 1, corresponding to a drag angle of 14 degrees. Assume the same for all the bits in the water. Then the sum of drag angles is 28 degrees, which is the closest you can sail to the apparent wind, and is reasonable for a decent boat.
Now assume you reef down to half the area.
Relative to the sail area, the hull is now twice as big. So for every 8 units of lift and 1 unit of drag from the sail, you get
2 units of aero drag from the hull, so the best lift to drag ratio is now 8 to (1 +
2). That increases your best aero drag angle to 20 degrees. Heeling might make that still worse. You don't reef your lateral plan in the same fashion, but let's say that additional drag from heeling and sailing over waves has the same effect of adding one unit of drag, so your hydro drag angle is also 20 degrees. Now your best course to apparent wind is 40 degrees.
But in 50 kn, you might have to reef down far more, say to one quarter of the sail area. And assume that the larger waves add another unit of drag. So for aero we have lift to drag of 8 to (1+
4), for an aero drag angle of 32 degrees, and for hydro we have 8 to (1 +
3) for a hydro drag angle of 27 degrees. Now your best course to the apparent wind is 59 degrees. If you manage that at 3 kn, that gives you a velocity made good to windward of 1.5 kn. Wind-induced surface current could eat up much, perhaps even all of that.
If you reduce the drive from your sail relative to the aero drag of your hull enough, you will not get to windward. If you impose the additional constraints of car-toppable and non-athletic, then you are looking for the maximum righting moment for a very limited weight, and you need to think about longitudinal stability as well as transverse. Two crew weigh more than a car-toppable boat, so their weight must be placed as far to windward as you can manage. If you don't want the crew to move about, windward must remain the same on both tacks, which gives you a proa. You could be sitting 4 metres to weather of the lee hull. Say 20 kg for ama and board, 150 kg for two crew, gives a force of 1668 N over a lever arm of 4 metres for a righting moment of 6672 Nm, over seven times as high as what you are considering. Look at Rob Denney's E25 for a boat in that size range:
E25 – Harryproa http://harryproa.com/?p=2820 Build a storm rig, so you don't have all the drag of a lot of unused mast high up in 50 kn.
For longitudinal stability, you can either go for a very long lee hull (you could build it in two easily handled halves that bolt together in the middle), or for beams that can swing towards either end. If you go for swinging beams, put most of the lateral area into the ama, so that wind forces in the lee hull and rig keep the boat unfolded. Guy Delage's proa Rosieres had no lateral resistance in the ama at all, and folded up at the start of a Route du Rhum (1982, I think) when he tried to swing the ama a little further back and the line slipped off the winch.
Of course, if you capsize anyway, you have a problem. If you want a boat in the desired weight range that can be made self-righting with ballast, water or otherwise, you won't get the stability you would need to carry a heeling rig in 50 kn. Then you will need to think about non-heeling after all, perhaps a kite.
