Slipway Winch
Discussion in 'Boat Design' started by abohamza, Jul 30, 2011.
  1. BATAAN
    Likes: 101, Points: 0, Legacy Rep: 1151
    BATAAN Senior Member
    Here are some photos. Notice that large railways sometimes use chain for a hauling cable. The third shot of a 3 screw tug on the ways is a yard I worked in for many years.
  2. David7438
    David7438 Junior Member
    Sorry! I am a junior about vessel operation. Can I ask some more simple questions? As follows:
    1.How to guide the vessel over the ways car? Using tug boat? or drive in position by the vessel(Is it possible ,especially for large vessel)?
    2.The arms and supports are adjusted by the divers?
    Thanks for your reply.
  3. BATAAN
    Vessel is guided into place gently with ropes and small boats. Supports are usually arranged so no diver is required, as divers cost money.
    This can either be pre-blocking to the plans of the vessel, or adjustable blocking or supports, usually operated with small hand winches and steel cable.
    This all depends on the shape of vessel being hauled. Some are easy, some are difficult.
    Google "marine railway" images and study closely.
  4. BATAAN
    Also, the safe design, build and operation of a large marine railway requires experience in the job and is no place for a beginner who knows very little about them.
  5. BATAAN
    Here is a short video of a working shipyard with 7 marine railways in southern Okinawa. Note the method of shoring KAISEI, a high-bilged and difficult to haul vessel.
    http://www.youtube.com/watch?v=vMMGjaOOamo
  6. David7438
    Thanks a lot! and Have a good night!
  7. David7438
    Do you have the experience of using concrete tracks?
    It's hardness and strength are smaller than steel, is it lasting long?
    Thanks for reply!
  8. mydauphin
    Likes: 54, Points: 48, Legacy Rep: 575
    mydauphin Senior Member
    You can break stuff and someone will get hurt...
  9. David7438
    Sorry! I am real a junior in the actual operation of vessel and associated facilities. And I hope that I could get some experienced information from this forum. Thanks for your stand.
  10. Amingenieria1980
    Amingenieria1980 New Member
    Hi everybody, I have a task to develop on the calculations of a shipyard that uses a slipway system that is pulled by an electric winche. They ask me to calculate the current pulled capacity of that Winche in tons. Could someone help me with ideas to start the calculations?
  11. Ad Hoc
    Likes: 2,019, Points: 113, Legacy Rep: 2488
    You will need to know the following:
    1. max weight to be moved
    2. the declination of the slipway (max angle)
    3. means of moving the weight... i.e. slipway...rails...trolley..etc
  12. Amingenieria1980
    Ok, I have the following initial information:
    1. max weight to be moved: This is what I need to calculate
    2. the declination of the slipway (max angle): 3,5ยบ
    3. means of moving the weight... i.e. slipway...rails...trolley..etc: Slipway with known dimensions
    Now, I have a question with the gears that help move the cables that drive the carriage. How is the required calculated?
  13. Ad Hoc
    The force "pull" required for your winch will be: force to overcome gravity + friction force
    F = W sin(theta) + (mu).W cos(theta).
    Theta = 3.5
    mu = whatever kind of slipway you have = its coeff. of friction
    W = weight of object
    bajansailor likes this.
  14. gonzo
    Likes: 2,412, Points: 123, Legacy Rep: 2031
    The OP needs to state the speed requirement. That will be one of the factors determining the necessary power. Also, there needs to be reserve power to get the ship moving.
  15. Ad Hoc
    There are indeed many issues that need to be taken into account.
    Ive designed several such system in the past....but it all starts with what is the max weight one wishes to launch/recover. ..??!!
