Slickcraft rebuild
Discussion in 'Fiberglass and Composite Boat Building' started by Art1848, Jul 22, 2016.
  1. Art1848
    Art1848 Junior Member
    I'm almost done with the demo part, I have a concern about the soaked foam that is below the 2' wide platform that is the floor for the fuel tank. this floor board runs all the way to the transom. Could I drill 2 or 3 inch holes in that flooring and dig the soaked foam out? also could a sump be made at the transom with a pump to help keep it dry? I hate to cover it up and let that wet sponge laying there. I hope the pics will help. Thanks.
  2. Ike
    Likes: 456, Points: 83, Legacy Rep: 1669
    Ike Senior Member
    You really need to replace that wet foam. Unfortunately you may have to remove the deck to get it out. When you replace it seal it up in glas an epoxy or polyvinyl plastic so it won't get saturated again. I suppose some of the others on this forum may know a way to get it out with out removing structure.
    fallguy likes this.
  3. Bosshoff
    Bosshoff New Member
    I would like to see an update on this stringer replacement project if Art1848 is still around.
  4. fallguy
    Likes: 1,619, Points: 123, Legacy Rep: 10
    fallguy Senior Member
    The foam saturated probably has no buoyancy value left.
    Remove.
  1. Art1848
  2. Mcdo2137
  3. revintage
  4. tuna_fan
  5. Mcdo2137
  6. Derek cord
  7. Russell Walters
  8. chowdan
  9. Rohde.Soda
  10. andysailor
