Slat seating
Discussion in 'Wooden Boat Building and Restoration' started by bobbrown, Apr 21, 2022.
  1. bobbrown
    Likes: 2, Points: 8
    bobbrown Junior Member
    Well I’m down to the seating... would like to use a series of slats.
    The question is... is there an industry standard for overhang and spacing? How about if you don’t intend on using cushions?
    Thanks all
  2. BlueBell
    Likes: 982, Points: 113
    Not that I'm aware of.
    Have a look around, patio furniture, etc.
    Thickness would be another variable, 1/2" slats?
    Width as well, 1", 1 1/2", 2"?
    Maybe research chair design but really, this should be pretty intuitive.
    Oh, and your supports, that would affect all of the above.
    Are you really in SE Georgia or USA?
  3. bobbrown
    Likes: 2, Points: 8
    SE. Georgia USA….thanks. I used to build a bunch of wood decks…our spacing both for seating and deck was a 16 penny nail or a speed square width. That’s about 3/16.
    The general thinking at the time was the spacing was safer for women’s shoes. Weather that’s correct or not…I have no idea…but that was the general thinking at the time.
    So..that’s my background on the subject. Just wondering what the current marine thinking is.
  4. messabout
    Likes: 511, Points: 113, Legacy Rep: 1279
    messabout Senior Member
    Alternative to slats is woven cane. If weight is of interest, the cane weave is better. Also a little more comfortable, less concentrated load, and more ventilation for ones glutes.
    BlueBell likes this.
  5. bobbrown
    Likes: 2, Points: 8
    Interesting idea. Thanks I’ll look into it
  6. BlueBell
    Canvas is another option.
  7. wet feet
    Likes: 441, Points: 83, Legacy Rep: 124
    wet feet Senior Member
    There's seating and then there is seating,which is to say that more details are needed.For slatted seats in a cockpit I'd start with something about 2"X7/8" and skim as little off when planing as I could get away with.A 1/4" radius on the top corners would be useful and then I'd decide whether they should be straight or swept-if the designer hadn't specified.Then it becomes a matter of fixing and finishing.
    If the seating is inside a cabin and intended to support cushions or mattresses just about anything strong enough wold suffice.It would almost certainly be less expensive to use plywood,unless you have your own stand of trees and a sawmill to convert them.
