PAR
Yacht Designer/Builder
- Joined
- Nov 12, 2003
- Posts
- 19,126
- Reaction score
- 508
- Location
- Eustis, FL
I have no doubt you could build a boat, but I do seriously doubt you could design one, that was anything close to successful, unless you count floating as the only goal.
Boat design is all about volumetics and simple math. It would be nice if we could just "wing it" based on some practical experience, which you seem to have, but it doesn't work this way. If you have difficulty with the volumetric aspects of the process, you'll never figure out how much boat you need, or how it (the volume) should be arrange. This doesn't even address the sail balance portions of the equations, which can delve into the black arts at times (well it seems like this to most) and don't even start me up on foil sections.
Without a basic understanding of the concepts and principles involved (such as how much a cat's hull should displace and where to distribute volume), you're best advised to by a set of plans, which are cheap, given the full scope of a project like this.
Yep Richard, they (L Gato) usually are seen with the main raked well aft and tend to plow a bit uphill, but given the age of the design, a reasonable trainer for a novice. It's not my cup of tea and I'm sure there's plenty of better choices, but it's the one I had at first glance, so I posted it.
Lastly, if your hull(s) displace 372 lbs. (6 cu. ft.) you'll be swimming a lot (couldn't resist).
