Simple idea, kinda.
Discussion in 'Multihulls' started by scoobert, Feb 23, 2013.
  1. gonzo
    I don't understand how you are going to add a top to a 12" half cylinder and make a cabin out of it.
  2. Submarine Tom
    Submarine Tom Previous Member
    Yes indeed, please post pictures and maybe have someone video the cutting part, from a distance.
    All the best!
    Great project.
  3. Number4
    Number4 Previous Member
    Not sure about that...
    I was watching a fitter cut the top off an empty 44 gallon drum of motor oil with an oxy torch.
    Just as he was finishing the cut it went bang! It must have gone 200 feet in the air, missed his head by 1 inch.
    He had a black face, no eyebrows, and all his hair was sindged. The startled expression was priceless.
    Cracked me up for weeks.:D
    You might want to have a quick look here.....
    http://www.osha.gov/pls/imis/AccidentSearch.search?acc_keyword="Diesel Fuel Tank"&keyword_list=on
  4. Submarine Tom
    I've just realized, OP stated 12 - 14 FEET by 60 FEET!
    LMAO!
  5. JSL
    Likes: 61, Points: 28, Legacy Rep: 41
    JSL Senior Member
    Diesel will explode if hot enough (at flash point) and the fuel/air mix is right--- sometimes more impressive than gasoline.
    Who wants to be a "Half Tanked" boat builder!
  6. rasorinc
    rasorinc Senior Member
    You could cut it with water under pressure. Or flood it with CO2, then use a torch. All our carriers can do that to the whole flight hanger and ammo storage areas and that saved the Lady Lex at Midway-one of the first to be able to do that. Lots of topside fires--none below. The Japanese did not know about this and 4 of theirs were sunk.
  7. redreuben
    redreuben redreuben
    Doesn't using a car exhaust to purge the tank also work ?
  8. Sundiver2000
    Sundiver2000 Junior Member
    Don't use a torch on a diesel tank. The heat gasifies the residue. Fill it with water, cut it with a worm drive circular saw (with a GFI).
  9. Submarine Tom
    The OP seems long gone here folks...
    I wonder where he/she could have gotten too...?
  10. whitepointer23
    Exactly. Fuel ships use there exhaust to fill the air spaces in tanks with carbon monoxide. I have repaired truck fuel tanks with this method. I suspect sub t does not have welding experience.
  11. Submarine Tom
    Can you say, "Ka-Boom!"
  12. jamez
    Likes: 32, Points: 28, Legacy Rep: 231
    jamez Senior Member
    When I was a teenybopper I worked in a car wrecking yard and we used the same method (car exhaust into the tank to de-petrol fume it) before brazing up any rust holes and painting.
