Note: This feature may not be available in some browsers.
Hi and thanks.Well done.
Receiving a compliment from an industry professional such as Gonzo is not to be taken lightly, he is wired to consider worst cases and warn you of your folly; and choses praises instead.
TANSL has made a kind offer and the site admin can possibly fix your title if you tell him what you want.
Is there an intention to build full size? This could be a massive thread like the sea sled one. He basically resurrected and modernised a ~100 year old fairly unique planing hull design and built it full size as a work boat.
Carry on! Looking forward to progress.
Tested the stability with Ship workbench. Last picture is of peak of curve.
Well, here at 50.5 deg heel, it looks like the diagram is spot on if you ask me. You can argue the stability would be better without deep deck, and I will agree. And yes, the last picture actually was peak curve. You picked the wrong picture for argument.Well...no.
Your boat has an open cockpit (no deck is shown)...ie..water will flooded it once the gunwhales are immersed.
Roughly guessing at which angle this is occurring...
Yes it is. I'm not sure how the boat carries the water it separates or lift away from the main body of water (ocean), which it hasn't done here. But one can clearly see on the diagram where the diminishing increase in stability towards Peak curve, because of the deck shape. I'm open for suggestion to my understanding. And the gunwale have buoyancy too.It looks like at 55 degrees the gunwale is under water.
I had to find out, so I asked something I don't like using. It said:Yes it is. I'm not sure how the boat carries the water it separates or lift away from the main body of water (ocean), which it hasn't done here. But one can clearly see on the diagram where the diminishing increase in stability towards Peak curve, because of the deck shape. I'm open for suggestion to my understanding. And the gunwale have buoyancy too.
Yes it is. I'm not sure how the boat carries the water it separates or lift away from the main body of water (ocean),....
