I'm planning to build a pair of 12' long amas for a canoe tri using cheap 3 ply fir marine ply. They will each consist of two sides, which will be stacked atop each other, joined along the keel and bow, and then opened up, propped open, and bulkheads fitted inside. I have a kind of crazy idea of buying some 2" dia fiberglass sleeve material, which comes folded flat, slicing it down one side, slipping it over the joint while the side is stacked, epoxy gluing it to each side piece, being careful not to get epoxy along the center. This will serve like a hinge as in stitch and glue. Fiberglass doesn't like to conform to corners, but this stuff is sold flat. The inside will be filleted and taped, and the outside taped. The top surface will have one plywood section for a step, the rest covered with doped aircraft fabric with stringers as needed for shape.
The canoe tri itself will have two side decks built between the akas, resulting in a rectangular area across the boat of 78" fore and aft by 72" across, recessed into the sides a bit. These side decks will provide a seating area & camping area under a boom tent. The amas and outboard akas will extend outward for a total beam of over 10' and be designed to fold up over and inward for transport at only 6' wide by 15' long.
At night, the central area of the original canoe will have netting stretched over it for a bed. The actual sailing rig will be a cambered junk rig made from very light fabric, considerably over size for the boat due to the instant reefing possible with such a rig. Leeboards will be fitted so they are under the side decks when folded up.
This is intended to be used for sailing some of the large fairly remote local reservoirs, and camping out. I'm building this from a wrecked canoe... I loaned it out and it came back wrecked ;-(
H.W.
H.W.
