Capt. Flint
Junior Member
- Joined
- Apr 17, 2018
- Posts
- 14
- Reaction score
- Location
- Alabama
Hey guys,
So, I've come to the part of my build where I can play around with the living quarters. Attached is my proposed design, which is doable with the space that I have. I'm going to be adding a shower, relocating the head, and adding two sinks. Now, maybe it's because I'm tired, but I cant seem to find anything regarding advice or diagrams online about the plumbing for said additions. So, here are my questions:
1) How should I go about adding two sinks? How would the plumbing be done for that?
2) The head on the boat originally was just a standard household toilet that was centered where the shower will be. A more traditional marine head will be installed and relocated. So, How do I need to do the plumbing for that?
3) Now for the real doozy, I want to add a shower. I've looked and I cant seem to find anyone that sells shower stalls for boats. If anyone knows of a company that does, then please comment the link. Anyhoo, I'm not real sure on how to go about making the shower. The only thing I can think of is to do the walls and flooring with plywood and epoxy over it, I guess fiberglass could work too. I can figure that part out, it's the plumbing part that I really need help with. I know "grey water" & "black water" cant be stored together, so that will require two tanks. If anyone has a diagram for a shower setup that would be great. Also, only part of the floor will have wood slits where the drain is located.
**I don't want the head and shower in the same room**
Thank you all for your comments, suggestions, and advice.
- Flint
- Flint
