Doug Lord
Flight Ready
- Joined
- May 26, 2009
- Messages
- 16,679
- Reaction score
- 354
- Location
- Cocoa, Florida
MCM, I tried to answer your questions in red below:
i meant the main hull having the main lifting foil.
which seems to be your 'Fire Arrow' set-up.
Wind pressure ? So, the main hull foil is unloaded because it hasn't started to pull down, or because the increasing wind pressure forces down the lee ama causing its foil to generate enough lift to hold the whole boat up ? Think of an ama with the buoyancy(about 200%) to fly the main hull as a pivot point-as the wind gets stronger the whole boat will pivot on the ama.On my boat the mainfoil lifts the main hull and the ama foil lifts the ama in light air until windforce unloads the mainfoil and loads up the ama foil so the ama is carrying most of the load. That leaves the mainfoil AND rudder T-foil working to control pitch which is a lot more pitch control than a "normal" tri has. The system makes it practical to tap into the advantages of an oversquare beam. The three greatest advantages of a lifting foil on the main hull(in addition to the rudder t-foil) are:
1) the ability to fly the main hull in very light air,
2) The fact that ,as the boat goes faster and the wind is stronger, the main foil is unloaded reducing induced drag substantially.
3) the ability to allow the main foil to develop down force adding to the RM substantially. Keep in mind that the wand system is set for a particular angle of heel, so if the boat exceeds that, the wand causes the main foil to generate downforce to return the boat to the designed angle of heel.You can reef the boat if the downforce stays constant-or not. The main foil acts like the ultimate in gust response-automatically adding RM with every gust. The system is quite versatile allowing the designed angle of heel to be changed by simply adjusting the length of the wand.
A single up-tip foil on the lee ama can do that ? yes, absolutely-look at the pictures of my test model under way-click on the picture.But what makes it possible is that the mainfoil ,working with the rudder T-foil, controls the ride angle of the UptiP ama foil-this is real important because it prevents the ama foil from having pitch excursions on its own. The main and rudder t-foil would also control the ride angle of a planing ama working with or without ama foil assist.
Do you think such a system is applicable to off-shore racing ? Yes I do and it would have the same advantages as on the small boat
And About the 'Fire Arrow' amas; will that stage one planning half hit the water mainly at sub-5knts ? The lee ama is in the water below 4-5mph(not knots) of boat speed. But the ama hull(first stage) is designed to plane in case the ama is sailing in conditions where the ama makes incidental contact with the water at speed.
I see that, but this ? Even without foils a 200% ama will fly the main hull sooner or later as the speed/wind increases(the boat pivots on the ama). On a square or oversquare tri this can take a lot of wind and also be unsafe. The real wide boat can carry loads of sail upwind but w/o foils the pitch resistance is more or less the same as a normal tri during a bearaway or gybe and that can be dangerous.
i understood the ama buoyancy generates RM by lifting itself - how can it also lift the main hull way over there ?See "pivot" comment above. The 200% ama can support the weight of the tri as the wind causes the boat to pivot on the ama causing the main hull to fly.
By the way, i do appreciate you taking the time to help me grok this.
Don't hesitate to ask any questions-I and others will try to help. The physics of what happens on my boat is sometimes difficult for even an experienced trimaran designer to understand-probably why this configuration has never been seen before. And a damn good reason to build a large RC model to test it.
