Ship's propulsion problem........
Discussion in 'Boat Design' started by singhmandy, Jun 28, 2007.
  1. singhmandy
    singhmandy Junior Member
    Hi all......
    I have this question which I am looking for an answer. Plz read the attached word file and try to answer the query.......
  2. colinstone
    colinstone Junior Member
  3. charmc
    Likes: 78, Points: 0, Legacy Rep: 840
    charmc Senior Member
    13.3 knots. With half the engines not operating (and declutched, presumably) thrust is reduced by half, to approx. 35,000 lbs. On the chart this crosses about 13.3 knots.
    I might be oversimplifying the problem; on the other hand, sometimes it's as simple as it looks. Yet I wonder if I missed something. Too easy? Trick question? :confused:
  4. Guest625101138
    I am making the assumption that engine power is halved with half the engines running. Drive prop efficiency remains the same and the non-powered props do not add any more drag - lets say they can spin freely.
    Design power at hull is:
    70,000 * 18 *6080/3600/550 = 3869HP
    Half power is 1935
    Try first speed approx of (18^3/2)^(1/3) = 14.3
    Check
    40,000 * 14.3 * 6080/3600/550 = 1756HP
    Try 15kts
    45000 * 15 * 6080/3600/550 = 2072HP
    Lets say 14.8kts
    Rick W.
  5. Guest625101138
    There is another way that might be simpler to arrive at the same answer.
    Just redraw the propeller thrust curve at half values and take the speed where it intersects the hull drag curve. You then do not have to make the assumption about the prop efficiency. The intersection is very close to the 14.8kts using the power calculation as you would expect.
    Rick W.
  6. singhmandy
    Thanks guys
    I need to thank all of you for answering my query......
  7. erik818
    Likes: 20, Points: 0, Legacy Rep: 310
    erik818 Senior Member
    Assuming that the propeller slip remains approximately the same around 14 knots with two engines as with four engines and 18 knots, two engines at full throttle will be working at a lower rpm than would four engines at full throttle. Lower rpm usually means less power, so two engines alone would not provide half the power of four engines. The propellers are optimised for four engines, not two.
    I don't know how to read the of engine power or propeller thrust as a function of speed from the diagram, so I'm not able to say what the power and hence the speed would be with two engines. Mayby the info is there, but if I really needed to know I would get hold of the dimensioning data (slip as a function of speed) of the propellers and the torque curve of the engines to solve the problem.
    Please correct me someone if I'm totally off track.
    Erik
  1. philSweet
  2. sun
  3. Anthony Appleyard
  4. Devu De Goa
  5. souravsandesh
  6. kilbysg
  7. mustafaumu sarac
  8. Squidly-Diddly
  9. Lietuvis
  10. ayouden
