Ships lengthening
Discussion in 'Hydrodynamics and Aerodynamics' started by Alexanov, Jun 6, 2020.
  1. Alexanov
    Likes: 30, Points: 38, Legacy Rep: 10
    Alexanov Senior Member
    How to predict speed of lengthen vessel if original vessel 1o9 m speed was 12 knots and we add 3om in parallel midbody? Engine and propulsion same as for original ship.
  2. Alik
    Likes: 384, Points: 93, Legacy Rep: 1306
    Alik Senior Member
    I would do it this way:
    - calculate resistance by existing method, say Holtrop,
    - 'anchor' these results to original ship performance - say, by coefficients and correction factors
    - calculate the new ship using Holtrop method and correction factors from old ship
    Alexanov likes this.
  3. Alexanov
    I think about something like that... thanks.
  4. Ad Hoc
    Likes: 1,945, Points: 113, Legacy Rep: 2488
    What method/procedure did you use to calculate the resistance of the original 109m length ship?
  5. TANSL
    Likes: 933, Points: 123, Legacy Rep: 300
    If you use the Holtrop-Mennen method you must recalculate the following values:
    • Waterline length
    • Length between Perp.
    • Moulded Draft at Lpp / 2
    • Displacement
    • Longitudinal C.of B. from AP
    • Center of bulb area above keel line
    • Waterplane area coefficient
    • Prismatic coefficient
    • Transom submerged area
    • Hull wetted surface
    • Bilge keels area
    In other words, there is no way to extrapolate the results from the initial boat to the new boat. You must perform the calculation as if it were a new boat.
  6. Alexanov
    CFD calculations.
  7. Ad Hoc
    Then why don't you simply rerun the CFD?
    With your new data points.
  8. Alexanov
    Finally we decided to calculate CFD for short vessel at required speed and long one with the same power to get new speed.
    Probably it will be most correct method.
  9. Ad Hoc
    That depends if you validated your first set of CFD results.
  10. Alik
    Alik Senior Member
    I would not trust any CFD only. Systematic series or regression methods, then CFD. Usually, if there is no tan test data, we do resistance curves by 2-4 methods (regression of systematic series), then CFD to finalize, say, stern shape.
  11. Alexanov
    We compared resistance value from CFD and several other sources. It’s quite close. Usually resistance prediction for ships with length/beam > 7 works very well in many different methods.
    Alik likes this.
