Sheathed OSB as plywood substitute
Discussion in 'Fiberglass and Composite Boat Building' started by DogCavalry, Nov 30, 2020.
  1. DogCavalry
    Likes: 1,792, Points: 113
    DogCavalry Senior Member
    There's no large plywood to be had right now. I'm considering using OSB as a substitute, and epoxy glassing the upper and lower surfaces. Anyone ever do this?
  2. fallguy
    :eek::eek::eek::(:mad::confused:
    glass up a 4x8 panel and jump on it; you'll have the answer
    DogCavalry likes this.
  3. Will Gilmore
    Likes: 531, Points: 113
    Will Gilmore Senior Member
    The manufactures of OSB claim all the same properties of plywood, but my expriencing is that it is heavier and hard on the hands. Joints are hard to cut accurately and thinner sheets are not availible. I would be willing to drive quite a ways to get some decent plywood for building something like a boat.
  4. Blueknarr
    Likes: 462, Points: 83
    Blueknarr Senior Member
    Might have some similarity to exterior plywood,,,but not to marine grade. Do a boil/freeze test
  5. DogCavalry
    Yes, that was my concern. Heavier, not as water resistant. Completely mummified in epoxy, theoretically ok. But there's always a penetration somewhere...
    With COVID-19, there's no place I can drive to that has 10'. It's gone, and the plants won't be making more until next spring at the earliest.
  6. Mr Efficiency
    Is the glue waterproof ?
  7. gonzo
    Likes: 2,298, Points: 123, Legacy Rep: 2031
    OSB is made in 4x8 ft sizes. If you need 10 ft it is easy to scarf plywood.
    Will Gilmore likes this.
  8. DogCavalry
    I can get a 10' by 17' piece of osb from one of my suppliers. They make Structural Insulated Panels, SIPs for us. That's the whole roof in one piece. But you're right. Scarfing is on. I felt time pressure and wanted to get 5 by 10's.
  9. ondarvr
    Likes: 690, Points: 113, Legacy Rep: 506
    ondarvr Senior Member
    The owner of an OSB manufacturer had a high end boat made with it....just because he could.
    The pics were posted here years ago. A quick Google search should find it.
  10. ondarvr
  11. DogCavalry
  12. fallguy
    Epoxy fixes much
    Will Gilmore and DogCavalry like this.
  13. Will Gilmore
    "All I need is some epoxy and a can of paint and I can make any carpenter look good." To quote my father.
    -Will (Dragonfly)
  14. gonzo
    It doesn't take much time to scarf plywood. All you need is a power planer.
  15. DogCavalry
    Just as an aside, I built my shelter out of basic Canadian OSB about 3 months ago. Lots of offcuts laying in puddles since then. Completely usable. Apparently Canadian exterior grade osb is on another level.
    Still too dense, though. Not strong enough for the weight.
