Shaver prop rope cutters, used by U Navy, anyone used this type?
sdowney717
Senior Member
Joined
Nov 13, 2010
Messages
1,600
Reaction score
118
Location
Newport News VA
The Propeller Rope Cutter Test | Darglow
Link to one
Quickutter Rope Cutter - Q-Marine International Ltd - Marine power and Propulsion
Stella Equipment Store Rope and Line Cutter
However being in the US, does anyone have a link to a shaver cutter for here?
And the price of the disc cutters is very high, maybe a shaver is cheaper?
Seeing I am hauled, been thinking of these cutter devices, the shaver seems simplest and better than the others.
It needs to be the shaver design, not the disc or spur cutter
ChatGPT said:
You're specifically looking for a shaver-style rope cutter (not disc, spur, or scissor designs) for your boat's propeller in the USA. Here's what I found:
What Is a Shaver-Style Rope Cutter?
A shaver cutter features fixed blades mounted to the P-bracket (or stern tube) and a spool or cylinder attached to the front of the prop hub. As debris is forced between the blades and the prop, it gets gradually “shaved” off—minimizing structural stress and drag compared to other cutter types. Yachting Monthlydarglow.co.uk
Proven Use Cases & Benefits
  • The Royal Navy, RNLI, and pilot boats have adopted shaver cutters for their robustness and effectiveness. Reports cite very minimal damage even in harsh conditions (e.g., only one failure in six years from chain debris). YBW Forum
  • They offer a gradual cut, unlike scissors that can suddenly apply massive loads, making them safer for the drivetrain. YBW Forum
  • Yachting Monthly’s 2015 test noted that shavers deliver reduced structural load and minimal speed loss, though they require precise machining for installation. Yachting Monthly
Availability in the USA
Unfortunately, no major manufacturers in the U.S. currently offer shaver-style rope cutters as an off-the-shelf product. The most commonly available models are disc or scissor types (like Shaft Shark or Stripper). Yachting MonthlyYBW Forum
That said, shaver cutters have been offered by certain specialized providers, often needing custom machining of the prop and possibly the P-bracket. Installation can require lathe work, spool fabrication, and precise alignment. YBW Forum
One web forum member, Neil_Y, mentioned their cutter (likely a shaver) has proven its worth and is used where installation space allows:
“The Royal Navy and the RNLI have … removed scissor cutters to fit shaver cutters … robust (one damaged in 6 years from chain) and effective.” YBW Forum
What You Can Do Next
1. Contact Specialized Suppliers or Marine Fabricators
Shaver cutters are still viable—you’ll probably need a custom job. Consider reaching out to:
  • High-end marine machinists or prop fabrication shops
  • Companies serving commercial, pilot, or military fleets
  • Marine engineering firms in the U.S. that can replicate the shaver design used by the RNLI or Royal Navy
2. Provide Key Measurements Upfront
To get accurate quotes, gather:
  • Shaft diameter
  • Gap between prop and P-bracket (ideally 10–35 mm) YBW Forum
  • Prop hub boss dimensions
  • Material and structure of your P-bracket (metal vs. GRP)
3. Consider Hybrid Solutions if Shaver Isn’t Available
If you can’t source a shaver, you might still use disc-type cutters (like Shaft Shark) until a custom shaver can be installed. But given your preference, it's worth pursuing the shaver path if practicality allows.
Summary Table
Cutter Type Availability in USA Pros (Shaver) Cons / Challenges
Shaver-style
Rare, specialized/custom only Low drag, gradual load, proven durability Requires precise machining, custom fit
Disc / Scissor types Widely available Off-the-shelf, easier to install Higher drag (scissors), less gradual cutting
I asked ChatGPT and it can't find a US seller, but I figure must be something here.
Looks like its collar is designed to bolt to the propeller, which makes the install more of a hassle. I don't see why it could not just have a split collar that attaches to a shaft.
I do get that for this to work well, it can not be allowed to slip on the prop shaft.
It is still very expensive for what you get metal wise. Too bad, it is a very simple type design.
I'm a bit late here, but back when I was mucking about with prop shafts the same firms who machined the shafts made other fittings like shaft brackets and rope cutters.
I'm thinking if you have such a facility close enough you could get a cutter(s) made up and fit them next time you're out. If you have your own drawings then most fabricators could do it.
