There is quite a bit of info on how to make waves but not much on reasoning or engineering. Modded trim-tab gadgetry that looks like bat-wings. impressive terms like "delayed convergence", pictures taken from the waterline that make the waves look like they'd support the big-gut dude on a mini-skim board. Nothing for an engineering basis tho.
I jumped into the wake-surf space when I traded my Ski Nautique 200 for a crossover SV211, with the problem of having it surf great and still be able to slalom ski & tube close to a tournament level, thus being two boats in one.
Tools for wakesurfers are stick-on surf gates, batwing trim tabs, and heaps of ballast.
After playing with all that, I turned it into a pump/impeller flow-in-a-pipe sort of problem.
Prop is the pump impellor- and larger diameter, less pitch is better to move more water
The boat rudder is a vertical flow gate that directs the flow, We want to direct water to the surfside.
Ballast #'s, total weight equates to wave energy, much like a swell volume in ocean surf. However we want to displace the total hull and still be efficient hoving through the water, so the pump impeller (prop) doesn't go ballastic or cavitate/slip too much.
My innovation is I reconfigured the boat, removing the hydrogate and installing a "split stinger" plate so I could redirect prop flow to the surf side, assisting the rudder. Non surfside plate is dropped, surfside is open
The boat is crabbed or drug back on the non-surf side using a bit of interceptor plate (corner of transom) so the rudder is turned to direct flow toward the surfer. That and listing the boat aids in directing prop flow offset and downward for a cleaner and higher wave
Theory, design idea, installation, and monster waves. Worked right out of the gate.
Next is to automate the interceptor plates
And perhaps add some mild hydro-foils to improve the slalom ski wake... I've already reduced weight to minimal ~3300 lbs & it's a big boat. I was thinking of quad pack of surfboard fins, horizontally mounted one set on base of rudder the other set on a tracking fin near bow of boat. Goal to have ~200lbs lift at 36 mph
