shallow water, outboard surface porpelle.
Discussion in 'Surface Drives' started by Gian Milan, Jul 11, 2011.
  1. Gian Milan
    Gian Milan Previous Member
    Hello everyone.
    I'm Gian, Italy.
    I want build a Shallow Water Boat and I designed what is in attachment.
    Is a boat in meters, long 5.5, wide 1.7, and 0.8 high.
    The rivers have absolutely no waves, are slow, with gravel.
    The boat, fully loaded weighs 650 Kg and fishing 0.1 meters, has to consume little and do not need to run.
    I would like to apply outboard (height adjustment with piston air).
    What can I bow?
    According to the tunnel you can make the effect of the demos that are here? http://www.flatscat.com/performance1.htm
    Ciao a tutti!
      File size:
      46.6 KB
      File size:
      63 KB
      File size:
      20.4 KB
      File size:
      109.5 KB
      File size:
      47.7 KB
      File size:
      53 KB
      File size:
      39.1 KB
      File size:
      53.5 KB
      File size:
      38.5 KB
      File size:
      32.9 KB
      File size:
      25.9 KB
      File size:
      47.7 KB
  2. Frosty
    Frosty Previous Member
    I like it--what engine will you use?
  3. Gian Milan
    For this I asked you opinion...in My opinion a Mercury 40/60 may be ok.
    Some idea about the bow mount?
  4. Gian Milan
    Some idea about the surface propeller to mount?
  5. gonzo
    Likes: 900, Points: 123, Legacy Rep: 2031
    That design will make the boat draw more (sink deeper). A flat bottom boat will have less draft.
  6. keysdisease
    Likes: 43, Points: 28, Legacy Rep: 324
    keysdisease Senior Member
    Tunnel hulls
    Yor concept is valid, and proven by ultra shallow running flats fishing boats in the States. The tunnel may make the boat draw a little more water at rest but will allow you to run shallower.
    Take a look here:
    http://www.fishnetdailynews.com/Archived/FishNetTunnelHull.htm
    and other places using search terms: flats boats tunnel hull
    If you don't need to plane than a there is no getting around a flat bottom as drawing the least amount of water.
    Steve
  7. Gian Milan
    Sure, Gonzo.
    But with a flat boat I can't install a jet.
    If a propeller (in or outboard engine) is installed, it must be under the keel.
    Or not?
    TU
    Gian
  8. Gian Milan
    My question is:
    the propeller, positioned at the end of tunnel, can be higher than the keel?
  9. gonzo
    If you install a jet, a flat bottom is a requirement. At least on the aft end.
