semi submerssible
Discussion in 'Education' started by Dr34m3r, Sep 27, 2019.
  1. Dr34m3r
    Likes: 4, Points: 18, Legacy Rep: 10
    Dr34m3r Senior Member
    Anyone have good reference for calculating steel weight for Compact Semi Submersible ?
  2. jehardiman
    Likes: 1,472, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    It really depends on the hull form, are we talking pontoons and columns, SEALION, or narco hauler?
  3. Dr34m3r
  4. jehardiman
    Assuming this is for the first turn around the design spiral, I'd estimate based upon SWATH builds that structural steel weight is 175% of the weight of the shell plating for the hull alone (i.e. bare hull weight without decks and house = shell weight + 0.75*shell weight). That hull form is very structurally inefficient. For a preliminary design, the class society is generally going to dictate the shell plating thickness, so a preliminary estimate of the supporting structure is needed. A typical steel ship hull weight is ~ 135% of the shell weight. The deckhouse will follow more normal convention of ~ 120% of the house plating. Once you have a viable preliminary design, you can flesh out primary, secondary, and tertiary loads, which will set the hull structure (Bulkheads, frames, longs, etc ) for the next weight estimate. Turn the crank through the design spiral several times and the weight will fall out.
    You DO NOT want to under-estimate the hull weight in the original concept. It is easy to add ballast, hard to add buoyancy.
