Alan Cattelliot
Senior Member
- Joined
- Jul 6, 2021
- Messages
- 524
- Reaction score
- 220
- Location
- La Rochelle (Fr)
I like rockets very much.
Note: This feature may not be available in some browsers.
Interesting thought. I note that the GC32 is quite narrow. Could have been part of the equation indeed.Would going narrow with a catamaran save enough weight to put that weight into an effective ballasted keel? The engineering and build would be, um, interesting….Carbon….. mmmmmmmm…….
What could be the cause of this ? Anglo-saxo are prone to speak about the bad habbits of french sailors in term of security. Could the market of multihulls be tinted as such, that it would become acceptable to sail with a boat that can capsize, without additionnal cares, allowing the overall risk to be balanced ?self righting may be a desire but not important to many in the industry.
21 foot wharrams are slow and heavy. I also think the more likely place to flip is where there are strong currents and contrary wind.... when you have 21 foot home built Wharram's sail the globe and race across the Atlantic (Cooking Fat), self righting may be a desire but not important to many in the industry.
I prefer active recovery to automatic, although there is no real distinction since any mechanical movements can also be automated by electric motors and pumps.
Manual righting is likely to end in tears, automatic/self righting is a whole lot better but the best solution is not capsizing.
The requirement is something that works on all points of sail with no crew input, no electronics, and regardless of whether sheets are cleated, stood on or tangled and has no relationship with sheet loads or wave size. Ideally, it should be easy to reset (ie, no trips to the end of a flogging boom).
The simplest I could come up with is a wand with a float on one end and a T bar with a cam cleat on the other. The sheet is led through a block with a tail which is in the cleat. When the hull leaves the water (heeling or pitchpoling), or gets to a predetermined height, the wand angle increases, the T rotates and the cam cleat releases. To reset, the sheet is eased, the tail replaced in the cleat and the sheet trimmed on.
Works best on a proa as only one is required. Works best with low sheet loads (balanced or self vanging rigs) so the cleat loads are low. Only works downwind with unstayed masts so the main can weathercock without hitting the shrouds.
Knowing that you won't capsize is a major stress reduction when sailing in gusty conditions, strong winds or at night. It makes cruising a whole lot more enjoyable and racing, especially shorthanded, much faster.
The model is discussed on p2 of this thread. It could be used in the cruisers, but the lee hull would only be usable for storage. It's unnecessary if an anticapsize fuse is installed.Hi Rob I always wanted to ask will proas self right "if" capsized? seem to recall a short video clip of I think it was you in a pool with a model proa self righting and just wondered would that also apply to the cruising proas you design?
