Note: This feature may not be available in some browsers.
The easy way to do it is to screw a cleat on the dash and go from the bench across with 1/2-3/4 plywood.
Submit a clean pic and I can explain if needed.
Thanks mateYou can also hinge each side of the orange and make a wet locker down below. Wet cuz it'll rain into it. Depends where you are. A rainy area would be harder to use as a locker. You'd need to keep it open when not in use.
