Pac12AfrerDark
Junior Member
- Joined
- Mar 17, 2020
- Posts
- 44
- Reaction score
- Location
- Utah
Hey everybody,
I have been lurking and lurking gathering info - but figured I would create a thread so I could ask specific questions.
First - Please be patient, I am green and above all I am looking for advice to re do this boat with saftey as #1 priority.
alright - onto the back story:
Picked this drift boat up for free (ok, I paid 20$ for it...) trailer, motor, and all. I was going to turn around and sell it, but honestly - I love fishing the Green, and I am never going to shell out 3k for a drift boat (I fish lakes too much, all other funds are being saved to upgrade the tracker, plus, I only fish the green 2 or 3 times a year). I sold the evinrude that came with it to fund this project - right now, my budget is about $600 to re finish it myself (based on motor sale).
So here was the boat when I picked it up (Picture 1,2,3).
Here is my general plan right now:
1) Pull all the oar / weight wood blocks off and flip the boat over
2) Sand the hull with 80 grit, feather out large glass areas, patch with West Marine TS101 (its what I have on hand) 1st question - what should I fair this repair with? I have no more fairing compound in the TS system left. (Picture 4 shows the style of what I will repair, the rest are deep scratches extending through the original gel coat)
3) De-Grease and shoot the bottom, here is what I ordered to get that done:
3a) Wax N Grease Killer Solvent Wash
3B) Coloring Agents for Gel Coats (Green and Dark Blue)
3C) Patch Aid for Gel Coat
3D) Sea Foam Green Gel Coat, Sea Hawk Paints
I am planning on using 33Oz LVLP General Purpos Air Spray Gun (going to drill the nozzle out to 2mm).
4) Sand and Polish The Bottom Coat Per this video (I will use cheaper tools)
This is as far as I have planned out right now... here is what I really could really use input with:
Pictures 5 and 6 show the general wear of the interior... How would you all go about finishing that off? I read on some of the Corvette Fiberglass body forums to clean it, then lay resin on it to seal. I was kind of thinking about cleaning it then smoothing it with fairing compounds, sanding down, then gel coating. Again - I could really use everyone's input here.
Picture 7 shows the middle row insert.. .honestly, I am at a loss here... my first thought was.. sand and clean the surface, then do a layer of CSM on the top and the bottom, fair, and gel coat... My second thought was use that original piece as a mold, and make a new one (bi axial, then csm, then biaxial, fair, gelcoat..) again, not sure... any input is really appreciated.
Picture 8 shows the seat holders that are blown out...I am thinking I will 1) make a card board template 2) cut out some plywood (do I need a special kind?) 3) lay that up in place with biaxial and csm fair, gelcoat.
Picture 9 - this ones got me boggled? looks like there was ply wood in there, I guess my thought is to cut that out and replace it, sort of the same process as what I describe to fix Picture 8.
All in all, this is going to take some SERIOUS doing, honestly typing up all this was kind of dis heartening thinking about all the work, but, it will get done slowly. If you guys could give me any advice on my plans, or materials I would appreciate it.
Last question.. My thought is its best to fix picture ten before flipping the boat and repairing / gel coating the bottom. agree?
If you guys could recommend a mat and resin for the repairs above I would really appreciate it.
Also, is referencing pictures like this the best way? of should I link them in the post with imgur?
Thanks everyone,
-Josh
Thanks everyone,
-Josh
