Guillermo, what makes a boat seaworthy is not a quantity of ratios, numbers and formulas, but the way the boat handles and survives heavy seas and brings its crew safely home.
Regarding the boats from the 40class, they are so close (by the class rules) that we can consider them, for seaworthiness evaluation, as a single boat.
Then we can have an imaginary boat that results from the accumulated sea experience of the 25 40class boats that had raced the “Route du Rhum”. This imaginary boat has sailed 85 000 miles, 21 266 of them under severe storm conditions (Beaufort scale 11 and 12). Those 21 266 stormy miles have taken place in 50 different big storms (25 boats x 2 storms).
This boat was not driven under normal cruising conditions, but merciless raced all the way (including storms) and it was not a crew, but a single sailor in it.
No matter the extreme circumstances this imaginary boat has done exceptionally well, regarding seaworthiness. For 96% of the way, the boat hasn’t had any problem worth mentioning, with the exception of a broken boom (knock-down by a huge breaking wave while de skipper slept inside). This situation didn’t prevent the boat from making the long way to the nearest Port (Azores) by its own means.
Only on one occasion has the boat met serious trouble: The skipper was sleeping inside while the boat was on autopilot doing 17 knots. The boat has surfed a huge wave and has buried itself in a freak wave coming from other direction. The boat stopped instantly and the skipper had a lot of luck in having survived the crash (several broken bones). Incredibly the boat didn’t lose the mast, but had several structural problems. The boat made some water but did not sink (it looks that the 4 closed compartments with 3m3 of closed cell foam that should warrant the boat’s unsinkability worked well). The boat floated without problem till a cargo ship was diverted to proceed to the rescue of the injured skipper.
It is important to underline that this accident would not have happened if the boat was not driven extremely in stormy conditions. 17 knots on autopilot is crazy enough for me; 17 knots on autopilot while sleeping inside the boat is madness, unless you are a very aggressive racer. And he certainly knew that he was taking a lot of risks.
It is important to notice, that on those 50 different extreme storms, the boat never capsized (rolled) no matter the 70k of wind and 7 meter breaking waves. The boat proved that it can be sailed safely in these extreme conditions on autopilot, with the skipper sleeping inside.
And it is also important to say that the conditions encountered in that race where the worst ever encountered in all editions of the event.
Guillermo, you say about one of class40 boats, comparing it with the RM 1200:
Let's analize here one of those modern fast french cruisers, 'A' categorized, from a top designer:
The RM 1200, designed by Marc Lombard .
But from my point of view, with that huge beam it will result .. not safe at all when at open ocean,
And here… for POGO 40 Cruiser (…Things are even worse.
Really dangerous when not in planning conditions.. . Or even in planning if you lose control.
May I point also that the average speed of all the 40class boats was of about 6.5 knots, and that is not a planning speed?
I would find these comments amusing, if they would not contribute to the misinformation of less informed members of this forum.
You know Guillermo, it is the sea that informs about the seaworthiness of a boat, not the ratios or your calculations. This boat has proven its seaworthiness in the most demanding sea conditions, and it is obviously a very seaworthy boat.
I think you should adapt your numbers and ratios to the reality and not the reality to your numbers and ratios.
I agree completely with Crag Cay when he says:
......"a bigger displacement seems more desirable".
To You!
Another example of why you can't separate personal preference from the notion of seaworthiness. ANY boat that returns its crew safely back to port is seaworthy. If you didn't enjoy the experience, then that boat is not seaworthy - for you. ....
Pick the boat that suits your needs, but be careful not to project your own preferences as being 'the only way to skin a cat'. Other boat / sailor combinations may be just as seaworthy, just less attractive to you.
Regards
